Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1
Security Guide
search filter icon
search icon
Document Information
1.  Oracle ILOM Security Principles and Considerations
Key Deployment Security Considerations for Oracle ILOM
Important Security Principles for Oracle ILOM
General Security Principles
Basic Security Principles
2.  Oracle ILOM Security at Deployment
Understanding the Default Settings of Oracle ILOM
Changing the Default root User Account
Understanding User Roles and Privileges
Enabling or Disabling Unwanted Services to Control Open Ports
Understanding the Single Sign-On Feature
Configuring the Oracle ILOM Web Interface for Maximum Security
Using SSL Certificates
Understanding Web Security Settings
Configuring the Web Interface Session Time-Out
Configuring the Oracle ILOM CLI for Maximum Security
Configuring the CLI Session Time-Out
Understanding SSH Key Generation
Using User SSH Keys
Configuring SNMP for Maximum Security
Differences Between SNMPv1/v2c and SNMPv3
SNMP Security Guidelines for Choosing Whether to Enable Sets
Understanding the Engine ID
Configuring Ws-Man for Maximum Security
User Authentication Services and Security
Configuring Banner Messages
Security Implications of Enabling Sideband Management
Security Considerations for a Local Management Connection
3.  Oracle ILOM Security After Deployment
Understanding the KCS Interface to Oracle ILOM
Understanding the LAN Interconnect Interface for Oracle ILOM
Connecting to Oracle ILOM Using Secure Protocols
Using IPMI 2.0 To Ensure Traffic Is Encrypted
Using Remote KVMS Securely
KVMS Encryption
Multiple User Sessions and Remote KVMS
Using the Host Lock Feature to Prevent Unauthorized Use
Using Serial Console Redirection (start /HOST/console)
Monitoring Audit Events to Find Unauthorized Access
Understanding the Physical Presence Check Feature
Changing Administrator Passwords Frequently
Updating to the Latest Firmware
All Oracle ILOM services can be optionally disabled, which results in the closing of the respective open network ports for those services. While most services are enabled by default, you might want to disable some features or change default settings to make the Oracle ILOM environment more secure. Any Oracle ILOM service can be disabled, but will result in the loss of features. As a general rule, enable only those services that are absolutely necessary in the deployed environment. The loss of features must be weighed against the security benefit of having fewer network services enabled.
The following table describes the impact of enabling or disabling each service.
Table 2-4 Services When Disabled
Service
Description
Result of Enabling/Disabling
HTTP
A non-encrypted protocol for accessing the Oracle ILOM web interface
Enabling this service provides faster performance than encrypted HTTP (HTTPS). However, using this protocol might result in sensitive information being sent over the internet without encryption.
HTTPS
An encrypted protocol for accessing the Oracle ILOM web interface
Enabling this service provides secure communication between a web browser and Oracle ILOM. However, because it requires having an open network port on Oracle ILOM, there is an increase in vulnerability to an attack, such as denial of service.
ServiceTag
An Oracle discovery protocol used to identify servers and facilitate service requests
Disabling this service makes it impossible for Oracle Enterprise Manager Ops Center to discover Oracle ILOM, and prevents integration into other Oracle automatic service solutions.
IPMI
A standard management protocol
Disabling this service might prevent Oracle Enterprise Manager Ops Center, as well as some Oracle management connectors to third-party software, from managing the system.
SNMP
A standard management protocol for monitoring the health of Oracle ILOM and monitoring received trap notifications
KVMS
A set of protocols for providing remote keyboard, video, mouse, and storage
Disabling this service makes the host console and remote storage functionality unavailable, preventing their use of the Oracle ILOM Remote Console and CLI Storage Redirection applications.
Ws-Man
A standard web-services protocol for management of a system
Disabling this service prevents the protocol from being used to manage Oracle ILOM.
SSH
A secure protocol for accessing a remote shell.
Disabling this service disallows command-line access over the network and might prevent Oracle Enterprise Manager Ops Center from discovering Oracle ILOM.
SSO
A single sign-on feature that reduces the number of times a user has to enter a user name and password
Disabling this service prevents launching KVMS without having to re-enter a password and allows drill-down from a CMM to a Blade SP without having to re-enter a password.
For information about enabling and disabling individual services, see the Oracle ILOM 3.1 Configuration and Maintenance Guide.
