Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1
Security Guide
search filter icon
search icon
Document Information
1.  Oracle ILOM Security Principles and Considerations
Key Deployment Security Considerations for Oracle ILOM
Important Security Principles for Oracle ILOM
General Security Principles
Basic Security Principles
2.  Oracle ILOM Security at Deployment
Understanding the Default Settings of Oracle ILOM
Changing the Default root User Account
Understanding User Roles and Privileges
Enabling or Disabling Unwanted Services to Control Open Ports
Understanding the Single Sign-On Feature
Configuring the Oracle ILOM Web Interface for Maximum Security
Using SSL Certificates
Understanding Web Security Settings
Configuring the Web Interface Session Time-Out
Configuring the Oracle ILOM CLI for Maximum Security
Configuring the CLI Session Time-Out
Understanding SSH Key Generation
Using User SSH Keys
Configuring SNMP for Maximum Security
Differences Between SNMPv1/v2c and SNMPv3
SNMP Security Guidelines for Choosing Whether to Enable Sets
Understanding the Engine ID
Configuring Ws-Man for Maximum Security
User Authentication Services and Security
Configuring Banner Messages
Security Implications of Enabling Sideband Management
Security Considerations for a Local Management Connection
3.  Oracle ILOM Security After Deployment
Understanding the KCS Interface to Oracle ILOM
Understanding the LAN Interconnect Interface for Oracle ILOM
Connecting to Oracle ILOM Using Secure Protocols
Using IPMI 2.0 To Ensure Traffic Is Encrypted
Using Remote KVMS Securely
KVMS Encryption
Multiple User Sessions and Remote KVMS
Using the Host Lock Feature to Prevent Unauthorized Use
Using Serial Console Redirection (start /HOST/console)
Monitoring Audit Events to Find Unauthorized Access
Understanding the Physical Presence Check Feature
Changing Administrator Passwords Frequently
Updating to the Latest Firmware
The Oracle ILOM Single Sign-On (SSO) service is an Oracle-proprietary protocol and feature that allows authenticated web users to launch the Remote Keyboard, video, mouse, storage (KVMS) application without having to re-enter a password, even though the KVMS application is running on a different system. For a blade chassis, it also allows an authenticated chassis monitoring module (CMM) user to navigate to a blade SP in the chassis without having to re-enter her or his user password.
The SSO protocol uses one-time-use credentials that are sent over the network between Oracle ILOM and the Oracle ILOM Remote Console and CLI Storage Redirection applications. The communication of these credentials is over a private, encrypted channel. These credentials are then used internally by the Oracle ILOM Remote Console and CLI Storage Redirection applications to authenticate the session. For a blade system, the SSO one-time-use credentials are sent between the blade SP and the CMM over a private VLAN.
The SSO feature can be disabled if the convenience of single sign-on is not required. For more information about enabling or disabling the SSO service, see the Oracle ILOM 3.1 Configuration and Maintenance Guide.
