Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1
Security Guide
search filter icon
search icon
Document Information
1.  Oracle ILOM Security Principles and Considerations
Key Deployment Security Considerations for Oracle ILOM
Important Security Principles for Oracle ILOM
General Security Principles
Basic Security Principles
2.  Oracle ILOM Security at Deployment
Understanding the Default Settings of Oracle ILOM
Changing the Default root User Account
Understanding User Roles and Privileges
Enabling or Disabling Unwanted Services to Control Open Ports
Understanding the Single Sign-On Feature
Configuring the Oracle ILOM Web Interface for Maximum Security
Using SSL Certificates
Understanding Web Security Settings
Configuring the Web Interface Session Time-Out
Configuring the Oracle ILOM CLI for Maximum Security
Configuring the CLI Session Time-Out
Understanding SSH Key Generation
Using User SSH Keys
Configuring SNMP for Maximum Security
Differences Between SNMPv1/v2c and SNMPv3
SNMP Security Guidelines for Choosing Whether to Enable Sets
Understanding the Engine ID
Configuring Ws-Man for Maximum Security
User Authentication Services and Security
Configuring Banner Messages
Security Implications of Enabling Sideband Management
Security Considerations for a Local Management Connection
3.  Oracle ILOM Security After Deployment
Understanding the KCS Interface to Oracle ILOM
Understanding the LAN Interconnect Interface for Oracle ILOM
Connecting to Oracle ILOM Using Secure Protocols
Using IPMI 2.0 To Ensure Traffic Is Encrypted
Using Remote KVMS Securely
KVMS Encryption
Multiple User Sessions and Remote KVMS
Using the Host Lock Feature to Prevent Unauthorized Use
Using Serial Console Redirection (start /HOST/console)
Monitoring Audit Events to Find Unauthorized Access
Understanding the Physical Presence Check Feature
Changing Administrator Passwords Frequently
Updating to the Latest Firmware
This section describes how to best configure the Oracle ILOM web interface for maximum security. This section contains the following topics:
Secure Socket Layer (SSL) certificates are used both to encrypt communication over a network and to ensure the authenticity of a server or client. Oracle ILOM includes a self-designed SSL certificate that allows the HTTP over SSL protocol to be used out-of-box, without the need for uploading a certificate. When connecting to the Oracle ILOM web interface for the first time, the user is notified that a self-signed certificate is being used and is asked to accept its use. Using the certificate provided, all communication between the web browser and Oracle ILOM is fully encrypted.
However, it is also possible to upload a trusted certificate for improved security. A trusted certificate means that the certificate is granted in conjunction with a trusted certificate authority. Using a trusted certificate from a known certificate authority ensures the authenticity of the Oracle ILOM web server. Using untrusted (self-signed) certificates opens up the possibility of a man-in-the-middle (MITM) attack.
For more information about uploading a custom SSL certificate, see the Oracle ILOM 3.1 Configuration and Maintenance Guide.
The Oracle ILOM web interface provides several configurable security settings. By default, Oracle ILOM is configured to allow only the strongest Secure Socket Layer encryption (SSLv3 and TLSv1) with the strongest ciphers. However, Oracle ILOM also supports SSLv2 as well as weaker ciphers. It might be necessary that you enable SSLv2 or “weak ciphers” to support older web browsers.
If possible, configure the web interface with the default secure settings. For more information about changing the HTTPS service settings, see the Oracle ILOM 3.1 Configuration and Maintenance Guide.
The Oracle ILOM web interface has a configurable session time-out. The session time-out determines how many minutes will lapse until an inactive web session is automatically logged out. This feature reduces the risk of an unauthorized user finding an unattended computer with an authenticated session to Oracle ILOM.
The default time-out is 15 minutes, which is suitable for most users. Lowering the time-out means that the user might have to re-enter his or her user name and password more often, as sessions expire. However, it will shorten the amount of time during which authenticated sessions remain active.
For information about changing the web session time-out, see the Oracle ILOM 3.1 Configuration and Maintenance Guide.
