Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1
Security Guide
search filter icon
search icon
Document Information
1.  Oracle ILOM Security Principles and Considerations
Key Deployment Security Considerations for Oracle ILOM
Important Security Principles for Oracle ILOM
General Security Principles
Basic Security Principles
2.  Oracle ILOM Security at Deployment
Understanding the Default Settings of Oracle ILOM
Changing the Default root User Account
Understanding User Roles and Privileges
Enabling or Disabling Unwanted Services to Control Open Ports
Understanding the Single Sign-On Feature
Configuring the Oracle ILOM Web Interface for Maximum Security
Using SSL Certificates
Understanding Web Security Settings
Configuring the Web Interface Session Time-Out
Configuring the Oracle ILOM CLI for Maximum Security
Configuring the CLI Session Time-Out
Understanding SSH Key Generation
Using User SSH Keys
Configuring SNMP for Maximum Security
Differences Between SNMPv1/v2c and SNMPv3
SNMP Security Guidelines for Choosing Whether to Enable Sets
Understanding the Engine ID
Configuring Ws-Man for Maximum Security
User Authentication Services and Security
Configuring Banner Messages
Security Implications of Enabling Sideband Management
Security Considerations for a Local Management Connection
3.  Oracle ILOM Security After Deployment
Understanding the KCS Interface to Oracle ILOM
Understanding the LAN Interconnect Interface for Oracle ILOM
Connecting to Oracle ILOM Using Secure Protocols
Using IPMI 2.0 To Ensure Traffic Is Encrypted
Using Remote KVMS Securely
KVMS Encryption
Multiple User Sessions and Remote KVMS
Using the Host Lock Feature to Prevent Unauthorized Use
Using Serial Console Redirection (start /HOST/console)
Monitoring Audit Events to Find Unauthorized Access
Understanding the Physical Presence Check Feature
Changing Administrator Passwords Frequently
Updating to the Latest Firmware
Oracle servers provide a standard, low-speed connection between the host and Oracle ILOM called a Keyboard Controller Style (KCS) interface. This interface is fully compliant with the Intelligent Platform Management Interface (IPMI) Version 2.0 specification and likewise cannot be disabled.
Any operating system user who has kernel or driver access to the physical KCS device is able to modify Oracle ILOM settings without authentication. Typically, only root or Administrator users can access this device. However, it is possible to configure most operating systems to provide wider access to this device.
An operating system user with KCS access can do the following:
Typically, the device is called /dev/kcs0 or /dev/bmc on Linux or Oracle Solaris and ipmidrv.sys or imbdrv.sys on Microsoft Windows. Access to this device, also referred to as a Baseboard Management Controller (BMC) driver or an IPMI driver, must be carefully controlled using the appropriate access control mechanisms that are part of the host operating system.
For information about how to control access to hardware devices, see the documentation for the host operating system.
