Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1
Security Guide
search filter icon
search icon
Document Information
1.  Oracle ILOM Security Principles and Considerations
Key Deployment Security Considerations for Oracle ILOM
Important Security Principles for Oracle ILOM
General Security Principles
Basic Security Principles
2.  Oracle ILOM Security at Deployment
Understanding the Default Settings of Oracle ILOM
Changing the Default root User Account
Understanding User Roles and Privileges
Enabling or Disabling Unwanted Services to Control Open Ports
Understanding the Single Sign-On Feature
Configuring the Oracle ILOM Web Interface for Maximum Security
Using SSL Certificates
Understanding Web Security Settings
Configuring the Web Interface Session Time-Out
Configuring the Oracle ILOM CLI for Maximum Security
Configuring the CLI Session Time-Out
Understanding SSH Key Generation
Using User SSH Keys
Configuring SNMP for Maximum Security
Differences Between SNMPv1/v2c and SNMPv3
SNMP Security Guidelines for Choosing Whether to Enable Sets
Understanding the Engine ID
Configuring Ws-Man for Maximum Security
User Authentication Services and Security
Configuring Banner Messages
Security Implications of Enabling Sideband Management
Security Considerations for a Local Management Connection
3.  Oracle ILOM Security After Deployment
Understanding the KCS Interface to Oracle ILOM
Understanding the LAN Interconnect Interface for Oracle ILOM
Connecting to Oracle ILOM Using Secure Protocols
Using IPMI 2.0 To Ensure Traffic Is Encrypted
Using Remote KVMS Securely
KVMS Encryption
Multiple User Sessions and Remote KVMS
Using the Host Lock Feature to Prevent Unauthorized Use
Using Serial Console Redirection (start /HOST/console)
Monitoring Audit Events to Find Unauthorized Access
Understanding the Physical Presence Check Feature
Changing Administrator Passwords Frequently
Updating to the Latest Firmware
As a faster alternative to the KCS interface, clients on the host operating system can communicate with Oracle ILOM over an internal high-speed interconnect. The interconnect is implemented by an internal Ethernet-over-USB connection, running an IP stack. Oracle ILOM is given an internal, non-routable IP address that a client on the host can use to connect to it.
Unlike the KCS interface, which relies on protected access to a hardware device, the LAN interconnect is available to all operating system users by default. Therefore, connecting to Oracle ILOM over the LAN interconnect requires authentication, just as if the connection were coming over the network to the Oracle ILOM management port.
In addition, all services or protocols exposed on the management network are made available over the LAN interconnect to the host. It is possible to use a web browser on the host to access the Oracle ILOM web interface or use a secure shell client to connect to the Oracle ILOM command-line interface. In all cases, a valid user name and password must be provided to use the LAN interconnect.
The LAN interconnect is disabled by default. When it is disabled, there is no Ethernet device visible to the host operating system and the channel does not exist. Oracle Hardware Management Pack helps provision and configure the LAN interconnect. Oracle Hardware Management Pack is a set of packages that is installed on the host operating system.
For information about configuring the LAN interconnect, see the Oracle Hardware Management Pack documentation at: http://www.oracle.com/pls/topic/lookup?ctx=ohmp
