Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1
Security Guide
search filter icon
search icon
Document Information
1.  Oracle ILOM Security Principles and Considerations
Key Deployment Security Considerations for Oracle ILOM
Important Security Principles for Oracle ILOM
General Security Principles
Basic Security Principles
2.  Oracle ILOM Security at Deployment
Understanding the Default Settings of Oracle ILOM
Changing the Default root User Account
Understanding User Roles and Privileges
Enabling or Disabling Unwanted Services to Control Open Ports
Understanding the Single Sign-On Feature
Configuring the Oracle ILOM Web Interface for Maximum Security
Using SSL Certificates
Understanding Web Security Settings
Configuring the Web Interface Session Time-Out
Configuring the Oracle ILOM CLI for Maximum Security
Configuring the CLI Session Time-Out
Understanding SSH Key Generation
Using User SSH Keys
Configuring SNMP for Maximum Security
Differences Between SNMPv1/v2c and SNMPv3
SNMP Security Guidelines for Choosing Whether to Enable Sets
Understanding the Engine ID
Configuring Ws-Man for Maximum Security
User Authentication Services and Security
Configuring Banner Messages
Security Implications of Enabling Sideband Management
Security Considerations for a Local Management Connection
3.  Oracle ILOM Security After Deployment
Understanding the KCS Interface to Oracle ILOM
Understanding the LAN Interconnect Interface for Oracle ILOM
Connecting to Oracle ILOM Using Secure Protocols
Using IPMI 2.0 To Ensure Traffic Is Encrypted
Using Remote KVMS Securely
KVMS Encryption
Multiple User Sessions and Remote KVMS
Using the Host Lock Feature to Prevent Unauthorized Use
Using Serial Console Redirection (start /HOST/console)
Monitoring Audit Events to Find Unauthorized Access
Understanding the Physical Presence Check Feature
Changing Administrator Passwords Frequently
Updating to the Latest Firmware
Oracle ILOM supports a number of different remote management protocols. In some cases, there are both encrypted and non-encrypted versions of the same protocol supported. For security reasons, use the most secure protocol, if possible. The following table lists the supported protocols and shows which protocols are encrypted.
Table 3-1 Supported Secure Protocols
Category
Secure/Encrypted
Non-encrypted
Web browser access
HTTPS
HTTP
Command-line access
SSH
None supported
IPMI access
IPMI v2.0
IPMI v1.5
Protocol access
SNMPv3
SNMPv1/v2c
