Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1 Documentation Collection
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Documentation Feedback
Product Downloads
Download Product Software and Firmware
Oracle ILOM 3.1 Firmware Version Numbering Scheme
Support and Accessibility
Quick Start
Oracle ILOM 3.1 – Quick Start
Factory Default Settings
Mandatory Setup Tasks
Connect to Oracle ILOM
Log In to Oracle ILOM
Add New Users to Oracle ILOM
Optional Setup Tasks
Set Identification Labels for a Managed Device
Modify Default Network Connectivity Settings
Install Software Using Remote KVMS
Daily Management Tasks
Check System Status and View Open Problems
Manually Clear Fault Messages
Manage Event and Audit Log Entries
View Power Consumption Metrics for a Managed Device
View Power Allocations for a Managed Device
Set Oracle SPARC Power Management Policy
View Power Consumption Statistics and History
Routine Maintenance Tasks
Collect System Information for a Managed Device
Locate a Managed Device Using the Locator LED
Modify the Power State on a Managed Device
Reset Oracle ILOM on a Managed Device
Update Firmware on a Managed Device
Log In to the Host OS From a Remote Serial Console
Initial Setup FAQs
Configuration and Maintenance
Setting Up a Management Connection to Oracle ILOM and Logging In
Establishing a Management Connection to Oracle ILOM
Logging In to Oracle ILOM Server SP or CMM
Configuring Oracle ILOM for Maximum Security
Setting Up and Maintaining User Accounts
Managing User Credentials
Configuring Local User Accounts
Configuring Active Directory
Configuring LDAP/SSL
Configuring LDAP
Configuring RADIUS
Modifying Default Settings for Network Deployment and Administration
Network Deployment Principles and Considerations
Modifying Default Management Access Configuration Properties
Modifying Default Connectivity Configuration Properties
Example Setup of Dynamic DNS
Assigning System Identification Information
Setting Properties for SP or CMM Clock
Suggested Resolutions for Network Connectivity Issues
Using Remote KVMS Consoles for Host Server Redirection
First-Time Setup for Oracle ILOM Remote Console
Launching and Using the Oracle ILOM Remote Console
First Time Setup for Oracle ILOM Storage Redirection CLI
Launching and Using the Oracle ILOM Storage Redirection CLI
Starting and Stopping a Host Serial Redirection Session
Host Serial Console Log Properties
Configuring Host Server Management Actions
Controlling Host Power to Server or Blade System Chassis
Setting Host Diagnostic Tests to Run
Setting Next Boot Device on x86 Host Server
Setting Boot Behavior on SPARC Host Server
Overriding SPARC Host Boot Mode
Managing SPARC Host Domains
Setting SPARC Host KeySwitch State
Setting SPARC Host TPM State
Setting Up Alert Notifications and Syslog Server for Event Logging
Configuring Alert Notifications
Configuring Syslog for Event Logging
Setting System Management Power Source Policies
Power-On and Cooling-Down Policies Configurable From the Server SP
System Management Power Supply Policies Configurable From CMM
Setting Power Alert Notifications and Managing System Power Usage
Setting Power Consumption Alert Notifications
Setting CMM Power Grant and SP Power Limit Properties
Setting SP Advanced Power Capping Policy to Enforce Power Limit
Setting SP Power Management Settings for Power Policy (SPARC)
Setting the CMM Power Supply Redundancy Policy
Performing Oracle ILOM Maintenance and Configuration Management Tasks
Performing Firmware Updates
Reset Power to Service Processor or Chassis Monitoring Module
Backing Up, Restoring, or Resetting the Oracle ILOM Configuration
Maintaining x86 BIOS Configuration Parameters
BIOS Configuration Management
Performing BIOS Configuration Tasks From Oracle ILOM
SAS Zoning Chassis Blade Storage Resources
Zone Management for Chassis-Level SAS-2 Capable Resources
Manageable SAS-2 Zoning-Capable Devices
Sun Blade Zone Manager Properties
Important SAS Zoning Allocations Considerations
Enabling Zoning and Creating SAS-2 Zoning Assignments
Managing Existing SAS-2 Storage Resource Allocations
Resetting Sun Blade Zone Manager Allocations to Factory Defaults
Resetting the Zoning Password to Factory Default for Third-Party In-Band Management
User's Guide
Oracle ILOM Overview
About Oracle ILOM
Oracle ILOM Features and Functionality
Supported Management Interfaces
Supported Operating System Web Browsers
Integration With Other Management Tools
Getting Started With Oracle ILOM 3.1
Navigating the Redesigned 3.1 Web Interface
Navigating the Command-Line Interface (CLI) Namespace Targets
Collecting System Information, Monitoring Health Status, and Initiating Host Management
Collecting Information, Status, and Initiating Common Actions
Administering Open Problems
Administering Service Actions: Oracle Blade Chassis NEMs
Managing Oracle ILOM Log Entries
Performing Commonly Used Host Management Actions (Web)
Applying Host and System Management Actions
Administering Host Management Configuration Actions
Administering System Management Configuration Actions
Troubleshooting Oracle ILOM Managed Devices
Network Connection Issues: Oracle ILOM Interfaces
Tools for Observing and Debugging System Behavior
Enabling and Running Oracle ILOM Diagnostic Tools
Real-Time Power Monitoring Through Oracle ILOM Interfaces
Monitoring Power Consumption
Monitoring Power Allocations
Analyzing Power Usage Statistics
Comparing Power History Performance
Managing Oracle Hardware Faults Through the Oracle ILOM Fault Management Shell
Protecting Against Hardware Faults: Oracle ILOM Fault Manager
Using fmadm to Administer Active Oracle Hardware Faults
Using fmdump to View Historical Fault Management Logs
Using fmstat to View the Fault Management Statistics Report
Using the Command-Line Interface
About the Command-Line Interface (CLI)
CLI Reference For Supported DMTF Syntax, Command Verbs, Options
CLI Reference For Executing Commands to Change Properties
CLI Reference For Mapping Management Tasks to CLI Targets
CLI Reference
Basic CLI Command Reference for Oracle ILOM 3.1
System Information and Management
Host and System Control
Oracle ILOM Initial Setup
System Monitoring and Status
System Inventory
Oracle ILOM Configuration Management
Oracle ILOM Help
SNMP, IPMI, CIM, WS-MAN Protocol Management
SNMP Overview
About Simple Network Management Protocol
SNMP Components
SNMP Command-Line Syntax Examples
Configuring SNMP Settings in Oracle ILOM
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (CLI)
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (Web)
Downloading SNMP MIBs Using Oracle ILOM
Manage User Accounts Using SNMP
Before You Begin – User Accounts (SNMP)
Configuring Oracle ILOM User Accounts (SNMP)
Configuring Oracle ILOM for Active Directory (SNMP)
Manage DNS Name Server Settings (SNMP)
Configuring Oracle ILOM for LDAP (SNMP)
Configuring Oracle ILOM for LDAP/SSL (SNMP)
Configuring Oracle ILOM for RADIUS (SNMP)
Manage Component Information and Email Alerts (SNMP)
Before You Begin – Component Information (SNMP)
Viewing Component Information (SNMP)
Managing Clock Settings, Event Log, Syslog Receiver, and Alert Rules (SNMP)
Configuring SMTP Client for Email Alert Notifications (SNMP)
Configuring Email Alert Settings (SNMP)
Monitor and Manage System Power (SNMP)
Before You Begin – Power Management (SNMP)
Monitoring the Power Consumption Interfaces (SNMP)
Maintaining System Power Policy (SNMP)
Managing System Power Properties (SNMP)
Manage Oracle ILOM Firmware Updates (SNMP)
Update Oracle ILOM Firmware (SNMP)
Manage Oracle ILOM Backup and Restore Configurations (SNMP)
View and Configure Backup and Restore Properties (SNMP)
Manage SPARC Diagnostics, POST, and Boot Mode Operations (SNMP)
Before You Begin – Manage SPARC Hosts (SNMP)
Managing SPARC Diagnostic, POST, and Boot Mode Properties (SNMP)
Server Managment Using IPMI
Intelligent Platform Management Interface (IPMI)
Configuring the IPMI Service
Using IPMItool to Run ILOM CLI Commands
Performing System Management Tasks (IPMItool)
IPMItool Utility and Command Summary
Server Management Using WS-Management and CIM
WS-Management and CIM Overview
Configuring Support for WS-Management in Oracle ILOM
Supported DMTF SMASH Profiles, CIM Classes and CIM Indications
Oracle's Sun-Supported CIM Classes
Document Conventions for Oracle's Sun-Supported CIM Classes
SNMP Command Examples
snmpget Command
snmpwalk Command
snmpbulkwalk Command
snmptable Command
snmpset Command
snmptrapd Command
Feature Updates and Release Notes
Feature Enhancements as of Oracle ILOM 3.1
Feature Enhancements Summary
Updates to Oracle ILOM 3.1.x Firmware
Initial 3.1 Point Releases for Servers and Sun Blade 6000 CMM
Deprecation Notice for WS-Man as of Oracle ILOM 3.2.1
Oracle ILOM 3.1 Known Issues
Documentation Titles in Translated Documents
Before You Begin
To add new local user accounts to Oracle ILOM, perform one of the following procedures:
  1. Add New Local User Accounts – Web Procedure
    1. In the Oracle ILOM web interface, click ILOM Administration > User Management > User Accounts.
    2. In the Users table, click Add.
      The Add User dialog box appears.
    3. Specify a name and new password for the user account, and then select a user role profile.
      Oracle ILOM enables you to select one of three user role profiles from the web interface: Administrator, Operator, or Advanced. For a description of each user role profile, see Oracle ILOM User Profile and Role Descriptions.
    4. To add the new user account properties, click Save.
  2. Add New Local User Accounts – CLI Procedure
    1. At the Oracle ILOM CLI prompt, type either: —> create /SP/users/username password=password—> create /CMM/users/username password=password
      For example:
      -> create /SP/users/user5Creating user...Enter new password: ********Enter new password again: ********Created /SP/users/user5
    2. To assign a role to the user account, type either:—> set /SP/users/username role=aucr—> set /CMM/users/username role=aucr
      For example:
      To grant all read and write privileges to user5 on the server SP, type:
      -> set /SP/users/user5 role=aucroSet 'role' to 'aucro'
      Note - aucro is equivalent to the setting the Administrator (administrator) profile.
      For more information about the user roles and privileges supported in Oracle ILOM, see the following table.
Example 1 Oracle ILOM User Profile and Role Descriptions
Assignable Profiles and Roles
Privileges Granted
The Administrator profile grants privileges for the following predefined user roles:
  • Admin (a)
  • User Management (u)
  • Console (c)
  • Reset and Host Control (r)
  • Read-Only (o)
The Operator profile grants privileges for the following predefined user roles:
  • Console (c)
  • Read-Only (o)
Advanced Roles
The Advanced Roles profile is configurable from the web interface only. Use this profile to grant privileges for any of the following predefined user roles:
  • Admin (a)
  • Console (c)
  • Services (r)
  • Read-Only (o)
admin (a)
The Admin (a) role, when enabled, grants read and write permissions to all Oracle ILOM system management functions with the exception of the functions that would require the Admin (a) role to have these additional user roles enabled: User Management (u), Reset and Host Control (r), Console (c), and Services (s).
user (u)
The User Management (u) role, when enabled, grants read and write permissions to all Oracle ILOM user management authentication features.
console (c)
The Console (c) role, when enabled, grants read and write permissions to perform these remote console management functions: remote console lock options, SP console history log options, launch and use Oracle ILOM Remote Console, and launch and use Oracle ILOM Storage Redirection CLI.
reset and host control (r)
The Reset and Host Control (r) role, when enabled, grants read and write permissions to perform these host management functions: host boot device control, run and configure diagnostics utilities, reset SP, reset CMM, sub-component service actions, fault management actions, SPARC TPM management actions, and SNMP MIB download operation.
read-only (o)
The Read-Only (o) user role grants read-only permissions to view the state of all Oracle ILOM configuration properties and to change the account password and session time-out properties assigned to the individual user account.
service (u)
The Services (s) user role, when enabled, grants read and write permissions to assist Oracle service engineers if on-site service is required.
administrator (aucro)
A combination of all these user roles (aucro), when enabled, grant read and write permissions to perform backup and restore configuration functions in Oracle ILOM.
Related Information
