As a best practice, you should always set up multiple tools release foundations, including a test environment for applying tools release fixes. This helps ensure that a stable environment exists before you promote fixes to your production environment. You can also use this same principle and procedure to set up multiple foundations of major tools releases, such as Tools Release 9.1 and Tools Release 9.2 (when applicable).
The procedures described in this document enable customers to target specific environments when they install a tools release. For example, customers can keep the production environment running on the existing foundation and apply the new tools release to all other environments. This configuration enables them to perform tests on the new foundation code without impacting the production environment. When they complete the testing, they can then apply the new tools release to production.
By completing the tasks below, you can configure your JD Edwards EnterpriseOne systems to handle many foundations on a single enterprise server. These tasks require that you reconfigure pathcodes and jde.ini files to set up multiple foundations, but once the initial tasks are completed, the new configuration requires very little maintenance.
Before you begin the installation, consider these factors:
The multiple foundation setup uses one security server process per port.
If you have multiple Enterprise Servers at different tools release levels, make sure each of them is pointing to the correct security data sources.
If you have multiple foundations or multiple Enterprise Servers at different tools release levels, a dual maintenance of users and passwords is required.
Before beginning installation of the Tools Release 9.1, check the associated readme.txt file for late-breaking information and requirements.
This appendix consists of the following tasks:
Section A.1, "Understanding Multiple Foundation Code on the Enterprise Server"
Section A.2, "Understanding Multiple Foundation Code on the Deployment Server"
Section A.3, "Working with Packages for Multiple Foundations"
Section A.7, "Setting up the Multiple jde.ini Files on the Deployment Server"
To install multiple foundations, you must first install and configure new system code on the Enterprise Server. This section includes these topics:
Section A.1.1, "Working With Tools Releases on the Enterprise Server"
Section A.1.2, "Registering an Existing Enterprise Server with Server Manager"
If your JD Edwards EnterpriseOne configuration includes multiple servers running JD Edwards EnterpriseOne host code (for example, additional application servers or data servers), then you will need to apply the procedures for installing multiple foundations to each server. For this type of configuration to work successfully:Make sure that the port settings for the [JDENET] section in the jde.ini match between all servers running the same foundation.
Ensure the new services are running on all servers.
Run PORTTEST successfully on all servers for all foundation releases that you have installed.
Refer to the JD Edwards EnterpriseOne Server Manager Guide as described in the section of this guide entitled: Section 1.3, "Understanding Server Manager and This Guide".
This section discusses these topics:
This section discusses how to create a new host code directory for an Enterprise Server running the Microsoft Windows operating system.
On the Enterprise Server, navigate to the drive and directory that contain the JD Edwards EnterpriseOne host code. For example:
cd x:\JDEdwards\E900\ddp
where z is the drive on which the JD Edwards EnterpriseOne host code is installed.
Create a new directory for the tools release you want to test. For example,
md x:\JDEdwards\E900\DDP\TR910TEST
The new directory will be used to store both the new tools release and the path codes that will access the tools release.
From the \JDEdwards\E900\ddp directory, select the path codes that you want to access the new tools release. Move (do not copy) the selected path codes into the newly created directory. For example:
For example, if you wanted to test the new tools release with all environments except Pristine (PRIST, PS), move the Development (DEV,DV), Prototype (CRP, PY) Production (PROD, PD) and path codes.
Do not copy the path codes. Instead you should always move them. You should not associate more than one tools release with an environment at the same time. For example:
cd x:\JDEdwards\E900\DDP\TR910TEST
move x:\JDEdwards\E900\DDP\TR910TEST\DV900 .
move x:\JDEdwards\E900\DDP\TR910TEST\PY900 .
move x:\JDEdwards\E900\DDP\TR910TEST\PD900 .
You must also copy (not move) the original SYSTEM folder for the moved path codes to the new directory. For example:
copy x:\JDEdwards\E900\DDP\SYSTEM .
In the new x:\JDEdwards\E900\DDP\TR910TEST directory, create the following subdirectories:
log
packages
PrintQueue
The resulting directory structure should like this (assuming you copied these three pathcodes):
c:\JDEdwards\E910\DDP\TR910TEST
\DV900
\PD900
\PY900
\log
\packages
\PrintQueue
\SYSTEM
\SYSTEM\bin32
This section discusses how to make the appropriate changes to the jde.ini file on a Microsoft Windows system.
Navigate to the \SYSTEM\bin32 directory under the new host code directory (for example: x:\JDEdwards\E900\DDP\TR910TEST\SYSTEM\bin32), and edit the jde.ini file.
Locate the [DEBUG], [INSTALL], and [BSFN BUILD] sections in the jde.ini file, and change the paths in each of these entries to point to the new host code directory:
Replace host_code_dir in the entries below with the name of the new host code directory.[DEBUG] DebugFile=d:\JDEdwards\ddp\host_code_dir\log\jdedebug.log JobFile=d:\JDEdwards\ddp\host_code_dir\log\jde.log JDETSFile=d:\JDEdwards\ddp\host_code_dir\log\JDETS.log
[INSTALL] E910=d:\JDEdwards\ddp\host_code_dir StartServicePrefix=JDEdwards Update x.x
where x.x is the tools release number. For example, 9.1.
[BSFN BUILD]
BuildArea=d:\JDEdwards\ddp\host_code_dir\packages
Locate the [JDENET] section, and find the port settings for serviceNameList and serviceNameConnect. For each entry, add 100 to the number. For example, if the settings are both 6013, change them to 6113.
[JDENET] serviceNameList=6113 serviceNameConnect=6113
In the [JDEIPC] section, add 1000 to the startIPCKeyValue entry as shown below:
[JDEIPC]
startIPCKeyValue=7000
If thestartIPCKeyValue value is commented out, delete the comment mark.In the [SECURITY] section, either clear security, or edit DefaultEnvironment to reference a valid environment that accesses the new tools release.
Replace all references to the production environment (for example, PD812) with a valid environment that will access the new tools release (for example, PY910).
Any Enterprise Server running Tools Release 8.97 and greater should be registered with Server Manager. For details, refer to the section entitled: "Register or Create a JD Edwards Enterprise Server as a New Managed Instance" in the JD Edwards EnterpriseOne Server Manager Guide.
To ensure that the new tools release is properly installed on the Enterprise Server, complete the following task to run PORTTEST on all environments accessing the new tools release.
If Security Server is on, then JD Edwards EnterpriseOne services must be running beforePORTTEST can be run.This section contains the following topics:
This section discusses how to run PORTTEST on a Microsoft Windows Enterprise Server.
On the Enterprise Server, open a DOS command window and change to the drive that contains the JD Edwards EnterpriseOne host code.
Enter these commands:
cd \JDEdwards\ddp\host_code_dir\System\bin32
PORTTEST userid password environment
where userid is a valid Tools Release 9.1 user, password is the password for that user, and environment is the environment you are verifying. These parameters are case-sensitive.
Repeat the PORTTEST command for each environment accessing the new tools release.
This section discusses how to manage Services on a Microsoft Windows Enterprise Server.
Enter the following commands:
cd \JDEdwards\ddp\host_code_dir\system\bin32
jdesnet -i
exit
From the Microsoft Windows Control Panel, open Services.
Select Tools Release Update x.xx E910 Network services.
Click Startup.
Select Manual.
Click This Account.
If your default printer is a local printer, enter a local user name and password. If your default printer is a network printer, enter a network user name and password.
Click OK.
Select Tools Release Update x.xx E910 Network Services, and click Start.
This chapter discusses:
Sign on to the Deployment server using the JDE user ID.
Make sure that all JD Edwards EnterpriseOne processes (for example, Solution Explorer) are not running.
On the Deployment server, navigate to this directory:
z:\JDEdwards\E910
where z: is the drive on which the JD Edwards EnterpriseOne host code is installed.
In the E910 directory, create a directory called
System_TR_Original
where TR_Original is the release number of the tools release currently installed. For example, System_894_M1.
From the \JDEdwards\E910 directory, copy (not move) the following directories to the new System directory (System_TR_Original) that was just created. This will serve as backup or rollback location for the previous release.
System
SystemComp
OneWorld Client Install
Caution:
Ensure you do not move these directories; they are required in both locations. This is because the installer needs to save a copy of thejdbj.ini and jas.ini files so you can relocate them in the new system directory.Note:
If you get a warning message, it indicates files are locked. You need to ensure that JD Edwards EnterpriseOne or any other application is not running and causing a lock on any file.If the Deployment Server is directly connected to the Internet, run the installation using one of these two methods to acquire the tools release:
Change Assistant
Directly from the Update Center
In either case it is recommended to save the downloaded executable to a temporary directory and run it later from there.
When you run the downloaded executable, you will receive a dialog indicating that the files are extracting.
On Installation Complete, click OK.
The program installs the new System, SystemComp, and OneWorld Client Install files and directories onto the Deployment Server.
In the E910 directory, create another new directory called System_TR_New where TR_New is the release number of the tools release being installed. For example, System_91_A1.
Move the newly installed System, SystemComp, and OneWorld Client Install files and directories into the new directory:
\JDEdwards\E910\System_TR_New
For example, \JDEdwards\E910\System_91_A1.
Restore the original directories by copying the System, SystemComp, and OneWorld Client Install directories from System_TR_original to the base installation directory x:\JDEdwards\E910.
Locate the jde.ini in this location:
\JDEdwards\E910\System_TR_New\OneWorld Client Install\Misc
Modify the above-located jde.ini to change the port to that on which you wish to run the multiple foundation. For example, valid ports might be 6014, 6015, etc.
On the Deployment Server, log on to the deployment environment.
From the Fast Path menu, run P9654A.
On Work with Locations and Machines, click Find and expand the location tree.
Click Enterprise Servers and then click Add.
On Enterprise Server Revisions, complete the following fields:
| Field | Description |
| Machine Name | Enter the name of your existing primary Enterprise Server. |
| Description | Enter a description for the machine. |
| Release | Enter E910. |
| Host Type | Click the visual assist button and select the type of Enterprise Server. |
| Port Number | This should match the port number previously set in the new tools release
| Database Type | Click the visual assist button and select the type of database being used on the Enterprise Server. |
| Installation Path | Enter the installation directory path in which Release 9.1 is installed on the Enterprise Server. |
Click OK.
For Oracle databases, the program prompts for a connect string. Enter or verify the connect string and click OK.On Work with Locations and Machines, click Find and expand the tree.
Expand the Enterprise Server, click the newly added machine and click Select.
On Enterprise Server Revisions, click the Environments form exit.
On Machine Environments Revision, add the environments which you want to access with the new tools release. You can add the environments either by typing their names into the grid or by selecting them using the visual assist.
Click OK twice to return to Work with Locations and Machines.
From the fast path menu, run P9654A.
Expand Enterprise Servers, click the initial Enterprise Server machine record and click Select.
On Enterprise Server Revisions form, click the Environments form exit.
Delete all the environments that you added in the previous section.
This should leave you with only those environments that you have defined to access the production tools release (for example, PD910).
Click OK twice.
Deploying the new tools release is easily done using the Package Build application by using a non-default foundation. Use these steps to create and include a new foundation for the multi-foundation tools release.
Sign on to the Deployment Server using the JDE user ID.
Sign on to EnterpriseOne using the JDE user ID into the Deployment (DEPXXX) environment.
Launch the Package Assembly application from menu GH9083.
On Package Component Revisions, select the Multi-foundation Update Package and enter a valid value for the Parent Package.
On Foundation Component Selection, search for and select the new update package you specified in the previous screen.
On Foundation Item Revisions, complete these fields:
| Item | Value | Description |
| Foundation Name | TR_NewVersion | Enter a unique name of the foundation.
For example, 896_A1. |
| Description | TR New Version | Enter a description corresponding to the new foundation name. |
| Service Pack Number | TR New Number | Enter an arbitrary tools release number where the maximum string value is four characters.
For example: 896A. |
| Release | E1 Release | Use visual assist to appropriately select the EnterpriseOne release level. |
| Platform Type | 99 – Client | Enter Client because the foundation is to be deployed to the development client workstation. |
| Build Type | 20 – Optimize | You must select optimize as the build type. |
| Foundation Build Status | 30 – Build is Available | You must identify the package build as available. |
| Date Built | Installed Date | Enter the date the tools release was installed. |
| Time of Build | Time of Installation | You can enter any time.
Typically you should enter the approximate time the installation was performed. |
| Foundation Machine Key | Deployment Server Name | Enter the UNC name of the deployment server. |
| Foundation Path | path | Enter the relative path to the new system folder.
Be sure to include the front –\– and the System directory at the end. For example:
Click OK to save the Foundation Item Revision information.
On Foundation Item Revisions, select the browse button.
On Foundation Component Selection, select the Multi-foundation Update Package by clicking the first column of the selected row.
Ensure that the checkmark displays in the first column of the selected row record.
Click Add to create a new foundation to be used.
On Package Component Revisions, verify that the Multi-foundation Update Package you added is displayed in the Foundation field and click OK.
On Package Build Revisions, select the Compression Options tab and select your compression options.
Click End to complete the Package Assembly process.
Proceed to build and deploy the package.
Use the procedure in this section to set up your Development Client.
On the GH9083 menu, launch the Package Build application.
Create an update package by selecting Package Assembly and then Add.
On the Work With Features, select Add.
On Feature Based Deployment Director, click Next.
On Feature Information, complete these fields:
| Feature Type | Enter a valid value for this feature type. |
| Feature Installation Options | Select your feature installation options by checking the appropriate check boxes. |
| Components | Verify this check box is selected:
Click Next.
On Package Assembly, Additional Install Processes, complete these fields:
Feature
Enter a meaningful name for the feature. For example, if you are using OAS:
WEBDEVOAS
If you are using WAS, an example would be
WEBDEVWAS
You can specify any name for the feature.
Feature Type
Enter the value1.
Description
Enter a description. For example:
Web Development Objects (OH4A) for OAS
or
Web Development Objects (H4A) for WebSphere Express
You can specify any name for the description.
Required
Ensure this option is selected.
Click Save.
Click Next.
Continue with the rest of the package assembly; there is no need to select any objects.
Define the package and, when prompted, make sure to select:
Build Feature Inf
Submit the package, which creates the new feature .inf for Web Development.
The newly created feature .inf file is located in the package.inf directory.
For any subsequent package builds for the non-default foundation for which you want to include webdev feature, you can use the package that you created with this procedure.Note:
If you are using Snapshot, you do not need to manually edit thejde.ini file to manage multiple clients for multiple foundations, as described in this procedure.This section describes editing the jde.ini file for a Development Client.
In order for the Release 9.1 clients to access the new tools release, you must edit the jde.ini file on each client to point to the new directory.
Complete the following task on all Release 9.1 clients that have path codes that will access the new tools release.
You will be unable to access multiple tools releases with a single client. To access multiple tools releases, you will need to install a different client for each tools release. This will require using the Snapshot application to save each client before installing the next one.On the Release 9.1 workstation, open Microsoft Windows Explorer, and navigate to your Microsoft Windows directory. For example:
cd c:\WINDOWS
Open the jde.ini file.
Locate the [JDENET] section, and edit the port settings for serviceNameListen and serviceNameConnect. Change these entries to match those of the server jde.ini file for the new tools release.
[JDENET] serviceNameList=portNumber serviceNameConnect=portNumber
where portNumber is the same port number you entered in the jde.ini file on the Enterprise Server.
This section discusses how to promote foundation code into the production environment when using a Microsoft Windows-based Enterprise Server.
On the Enterprise Server, stop the Release 9.1 services for the following environments:
The environment that you want to promote to production
The production environment
Navigate to this directory:
z:\JDEdwards\ddp\E910
Create a directory called System Backup, and move the System directory into the System Backup directory.
z:\JDEdwards\ddp\foundation_code_dir
Copy the System directory to this directory:
Navigate to this directory and copy the jde.ini file.
z:\JDEdwards\ddp\E910\System Backup\System\bin32
Paste the jde.ini file into this directory:
z:\JDEdwards\ddp\E910\System\bin32
The program asks if you want to replace the existing jde.ini file. Click OK to indicate you want to replace the existing jde.ini file.
Start the JD Edwards EnterpriseOne services.
On the Deployment Server, create a System Backup subdirectory under the JD Edwards EnterpriseOne host code directory. For example
z:\JDEdwards\E910\System Backup
Copy the System and SystemComp directories into the System Backup directory.
Navigate to the directory containing the system code being promoted. For example:
z:\JDEdwards\System x.xx
where x.xx is the release number of the tools release
Move the System and SystemComp directories to this directory:
z:\JDEdwards\E910
Using P9654A, edit the machine records to include the environments that you want to access the promoted tools release.
You may need to set up multiple jde.ini files on the Deployment Server to address the requirement for the Development Client to access different pathcodes and ports for different application releases of JD Edwards EnterpriseOne. For details, refer to the appendix of this guide entitled: Appendix C, "Data by Pathcode".
