26 Deinstalling the Software
This chapter includes these tasks:
26.1 Understanding the Deinstallation
The installation and upgrade processes do not automatically remove any JD Edwards EnterpriseOne databases. You should have a database administrator (DBA) for your relational database management system (RDMS) manually remove any unused databases according to the list of databases and associated components, which are provided in this document.
The deinstallation program restricts you from deinstalling a mandatory component without also removing all associated optional components that were previously installed. The relationship between the mandatory and optional components is shown in this table:
Server Mandatory Component Optional Components
Deployment Server JD Edwards EnterpriseOne Files Production Environment
Prototype Environment
Development Environment
Pristine Environment
Enterprise Server JD Edwards EnterpriseOne Foundation ES Production
ES Prototype
ES Development
ES Pristine
26.2 Deinstalling the Software from the Workstations
You can remove previous JD Edwards EnterpriseOne installations from workstations by running the deinstallation program as described in the JD Edwards EnterpriseOne Development Client Installation Guide.
26.3 Deinstalling the Local OEE from the Deployment Server
Oracle products use the term "deinstall" to refer to removing an Oracle product.
To deinstall the local Oracle database:
  1. Either export the local database tablespaces or deinstall JD Edwards EnterpriseOne using Start > Programs > Oracle - <Home_Name> > Oracle Installation Products > Universal Installer where <Home_Name> is the name that you gave the installation of EnterpriseOne on the Deployment Server.
  2. Locate this file:
    <Oracle_Home>\deinstall\deinstall.bat
  3. Right click on the file that you located in Step 2 and select Run as administrator, where <Oracle_Home> is the directory where you installed the local Oracle database. For example, your directory might be:
    c:\Oracle\E1Local
  4. At the end of the deinstallation, verify that the Oracle_Home directory has been deleted (for example, c:\Oracle\E1local). If it still exists, you should attempt to manually delete it.
    Caution:
    Prior to any reinstall an Oracle local database on this same machine, the Oracle_Home directory (for example, c:\Oracle\E1local) must not exist. If you attempt to reinstall the local Oracle database and this directory still exists, it is likely that the new installation will fail.
    Tip:
    You may not be able to delete the Oracle_Home directory (for example, c:\Oracle\E1local) if a process has it locked. In that case, to determine which process(es) has it locked, run the steps in the section of this guide entitled: Section 3.10.5.4, "Process Explorer".
26.4 Manual Cleanup of a Deinstalled Oracle Database on the Deployment Server
If the deinstallation of the OEE database fails for some reason, you need to perform the manual steps in this procedure to completely remove the old installation before reinstalling the database.
  1. Deinstall the Deployment Server.
    Be sure the Deployment Server is deinstalled before attempting to deinstall the database. This should ensure that no EnterpriseOne tablespaces are imported (attached) to the EnterpriseOne database.
  2. Delete the following registry keys:
    \HKEY_LOCAL_MACHINE\SOFTWARE\ORACLE\KEY_E1Local
    \HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ORACLE\KEY_E1Local
    \HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\(see Keys below)
    Keys. Delete any keys with names that start with "Oracle" and contain "E1Local".
  3. Delete this directory:
    c:\Oracle\E1Local
    If you cannot delete the E1Local subdirectory because a file in that directory is locked, follow these steps:
    1. Determine which file is locked and which process has the lock on the file. A freeware program called Process Explorer can be helpful in determining this information. You can obtain a free copy of Process Explorer from this web site:
      http://technet.microsoft.com/en-us/sysinternals
    2. Either kill the locking process with Process Explorer or Microsoft Windows Task Manager or, if the process was started as a Microsoft Windows service, change the Startup Type to Manual and reboot the computer again.
    3. Try again to delete the E1Local subdirectory.
  4. Remove the 64-bit Oracle inventory entries.
    1. With a text editor (such as Notepad), edit this file:
      c:\Program Files\Oracle\inventory\ContentsXML\inventory.xml
    2. Delete any lines that start with:
      <HOME NAME="E1Local"
    3. Save the file.
  5. Remove the entry from the Windows PATH.
    1. Navigate to Control Panel > System.
    2. Click Advanced system settings on the left.
    3. Click Environment Variables… near the bottom.
    4. In the System variables box near the bottom, highlight Path and click the Edit… button.
    5. In the Variable value field, delete this value:
      c:\Oracle\E1Local\bin
      Be sure to remove the semicolon as well.
    6. Click OK.
  6. Remove the ORACLE_HOME Windows environment variable.
    4. In the System variables box near the bottom, highlight ORACLE_HOME and click Delete.
    5. Click OK.
26.5 Using the OUI Installer to Deinstall JD Edwards EnterpriseOne from the Deployment Server
You can use the OUI installer to deinstall JD Edwards EnterpriseOne from the Deployment Server. To deinstall the local database, depending on your local database type, refer to the preceding sections of this guide entitled: Section 26.3, "Deinstalling the Local OEE from the Deployment Server".
To use the OUI installer to deinstall JD Edwards EnterpriseOne from the Deployment Server:
  1. Log on to the Deployment Server as a user with Administrator rights.
    Caution:
    Ensure that the Administrator account name that you use does not contain any special characters.
  2. If JD Edwards EnterpriseOne is running on the Deployment Server, stop it.
    Use Task Manager to verify these processes are stopped:
    • activConsole.exe
    • jdenet_n.exe
    • java.exe
    If any of these processes are running, either wait for them to finish or kill them via Task Manager.
  3. Go to Start > All Programs > Oracle - JDE_DEP910_Home > Oracle Installation Products > Universal Installer.
    Surrounding text describes oui_dep_svr_deinstall_wel.gif.
  4. On Oracle Universal Installer: Welcome, select the Deinstall Products ... button.
    Surrounding text describes oui_dep_srv_deinstall_inv.gif.
  5. On Inventory, with the Contents tab select, put a check mark next to the Oracle Homes for the Deployment Server Home.
    For example, if you followed recommendation in this guide the Oracle Home for your Deployment Server is:
    JDE_DEP910_HOME
  6. Select the Remove button.
    Surrounding text describes oui_dep_svr_deinstall_con.gif.
  7. On Confirmation, verify that you want to deinstall the listed components and their dependent components and if so, select the Yes button.
    Surrounding text describes oui_dep_svr_deinstall_prog.gif.
    The Remove dialog indicates the progress of the deinstall action.
    Surrounding text describes oui_dep_svr_deinstall_done.gif.
  8. When the deinstallation process completes, the Inventory is shown again. The products you selected for deinstallation should no longer be displayed in the inventory.
  9. Select the Close button.
    You are returned to the Oracle Universal Installer: Welcome screen.
  10. On Oracle Universal Installer: Welcome, select the Cancel button to exit the Oracle Universal Installer.
26.6 Dropping DB2 UDB Databases
This section lists the DB2 UDB databases that must be manually dropped by a DBA. This is the list of databases that were created by the JD Edwards EnterpriseOne 9.1 Installation of the Platform Pack on your Enterprise or Database Server for your JD Edwards EnterpriseOne installation, or from a previous JD Edwards EnterpriseOne installation.
By design, these databases are not automatically removed by the JD Edwards EnterpriseOne deinstallation program. You should have a DBA for your RDBMS manually remove any unused databases listed in the table below.
When removing DB2 UDB, you must drop all the tables within the tablespaces you want to remove, then drop the tablespaces (which automatically removes the indexes).
Tip:
The JD Edwards EnterpriseOne installer delivers sample scripts which you can use as examples of how to drop the databases. You should examine and edit these to suit your needs with the understanding that they have not been delivered 'ready to run '. You should pay attention to environment variables and arguments the scripts are expecting. Your DBA may prefer to drop the databases themselves instead of using scripts.
Sample drop scripts are located in the UDB directory under the JD Edwards EnterpriseOne installation directory (E910):
drop_db.sh (run signed on as instance owner)
drop_db.bat
You should also be aware that when you run the JD Edwards EnterpriseOne deinstaller, the directory structure containing sample drop scripts is deleted.
DB2 UDB Database Name (Alias) JD Edwards EnterpriseOne Component Schema Tablespace JD Edwards EnterpriseOne Purpose
OWSH910
(JDE910)
Foundation SVM910 svm910i
svm910l
svm910t4k
svm910t32k
Server Map
SY910 sy910i
sy910l
sy910t4k
sy910t32k
System
OL910 ol910i
ol910l
ol910t4k
ol910t32k
Object Librarian
DD910 dd910i
dd910l
dd910t4k
dd910t32k
Data Dictionary
OWSH910
(JDE910)
Development Object Specifications DV910 dv910i
dv910l
dv910t4k
dv910t32k
Central Objects and Versions
CRP Object Specifications PY910 py910i
py910l
py910t4k
py910t32k
Production Object Specifications PD910 pd910i
pd910l
pd910t4k
pd910t32k
Pristine Object Specifications PS910 ps910i
ps910l
ps910t4k
ps910t32k
OW_PROD
(JDE_PROD)
Production Environment PRODCTL prodctli
prodctll
prodctlt4k
prodctlt32k
Production Control Tables
PRODDTA proddtai
proddtal
proddtat4k
proddtat32k
Production Data
OW_DEV
(JDE_DEV)
Development Environment TESTCTL testctli
testctll
testctlt4k
testctlt32k
Development Control Tables
TESTDTA testdtai
testdtal
testdtat4k
testdtat32k
Development Data
OW_PS910
(JDE_P910)
Pristine Environment PS910CTL ps910ctli
ps910ctll
ps910ctlt4k
ps910ctlt32k
Pristine Control Tables
PS910DTA ps910dtai
ps910dtal
ps910dtat4k
ps910dtat32k
Pristine Data
OW_CRP
(JDE_CRP)
Prototype Environment CRPCTL crpctli
crpctll
crpctlt4k
crpctlt32k
CRP Control Tables
CRPDTA crpdtai
crpdtal
crpdtat4k
crpdtat32k
CRP Data
26.7 Removing System Accounts for DB2 UDB
This section lists the DB2 UDB system accounts that must be manually dropped by a DBA. This is the list of system accounts that were created by the JD Edwards EnterpriseOne 9.1 Installation of the Platform Pack on your Enterprise or Database Server for your JD Edwards EnterpriseOne installation, or from a previous JD Edwards EnterpriseOne installation.
The database users are not automatically removed by the JD Edwards EnterpriseOne deinstallation program. You should have a DBA for your RDBMS manually remove any unused items listed in the table below.
Database Name System Account
SY910
OL910
DD910
SVM910
SY910
OL910
DD910
SVM910
You should also remove this System Group:
  • JDESHARE (system group)
You should also remove these users of the JD Edwards EnterpriseOne system:
  • jde
  • applead
  • produser
  • devuser
Production PD910
PRODDTA
PRODCTL
Note: For your installation, the proddta and prodctl users may be needed for a previous release.
Pristine PS910
PS910DTA
PS910CTL
Development DV910
TESTDTA
TESTCTL
Note: For your installation, the testdta and testctl users may be needed for a previous release.
Prototype PY910
CRPDTA
CRPCTL
Note: For your installation, the crpdta and crpctl users may be needed for a previous release.
26.8 Deinstalling the Platform Pack
You should always use the JD Edwards EnterpriseOne OUI-based installation program to remove JD Edwards EnterpriseOne. If you manually remove the software, the deinstallation cannot be guaranteed to be complete and, as a result, subsequent reinstallation of JD Edwards EnterpriseOne may be hindered.
When you first ran the Platform Pack installer, to complete the installation you ran the addacct.sh script to lock down permissions to this directory:
/u01/jdedwardsppack/e920
Prior to rerunning the Platform Pack installer for any purpose, you must run the installer_chmod.sh script to unlock and change permissions to allow the installer to execute. On the machine which you initially installed the Platform Pack:
  1. Sign on as the root user.
  2. Change directory to the location of the Platform Pack installer. For example:
    cd /u01/jdedwardsppack/e920_1/SharedScripts
  3. Run the installer_chmod.sh script to change permissions so the Platform Pack installer can be re-run:
    . ./installer_chmod.sh
It is also very important you drop your DB2 UDB databases prior to running the deinstaller, as specified in the warning in the section entitled: Section 26.6, "Dropping DB2 UDB Databases". If you do not do this you will lose the drop.sh script that was delivered in the installation, because it will be removed by the deinstaller.
  1. Locate and execute the runInstall file under the /install subdirectory. Typically the directory structure of the extracted install image is similar to that shown below:
    Surrounding text describes ppack_structure_unix_udb.gif.
    The byte counts in this example will likely not match those of your unzipped files.
    Caution:
    You must sign on as the UDB instance owner in order to run the runInstall file. You cannot run a OUI installer as root.
    The installer requires that you are signed on as the UDB database user, even if you are only installing the Logic portion of the Platform Pack. You must install the UDB database client software and sign on as the owner of that install when running the Platform Pack. The Installer uses information about this account to configure the enterpriseone.sh. If you sign on as any other user, you will see errors during the install and will need to manually configure the database variables in enterpriseone.sh.
    This image is described in surrounding text.
  2. On Oracle Universal Installer, Welcome, click the Deinstall Products… button.
  3. Turn on the check box next to the Oracle Home for the Platform Pack and expand the node to show all installed components. For example, the Oracle Home might be named JDE_PPack910_Home.
    At this step, you should select only the Oracle Home that is associated with this particular OUI. That is, the Oracle Home name that you select on this screen should match the Oracle Home name that you selected from Start > Programs.
  4. Click the Remove… button.
  5. On Confirmation, verify that you want to deinstall the listed components and their dependent components and if so, select the Yes button.
    Surrounding text describes deinstall_ppack_progress.gif.
    Surrounding text describes deinstall_ppack_inv_done.gif.
  6. When the deinstallation process complete, the Inventory is shown again. The products you selected for deinstallation should no longer be displayed in the inventory.
  7. Select the Close button.
  8. On Oracle Universal Installer: Welcome, select the Cancel button to exit the Oracle Universal Installer.
  9. Verify that the installation directory (Oracle Home) has been deleted. If it still exists, you can delete it.
