4 Working With the Client Full Package
This section discusses:
4.1 Understanding the Client Full Package
The package build and assembly process includes many critical tasks that must be successfully completed to correctly install packages. See JD Edwards EnterpriseOne Tools Package Management Guide for details on building, assembling, and deploying packages. That guide lists most of these tasks and gives step-by-step instructions for completing them.
It is necessary to build a Full Client and Server Package when upgrading to the Tools Release 9.1. If this tools release has an enterprise server download, you must first upgrade the enterprise servers before you upgrade the workstations. If the enterprise servers are not upgraded first, they may not be able to properly receive and process requests from workstations that are upgraded.
4.2 Creating the Client Full Package
To create the client full package:
  1. Sign on to EnterpriseOne.
  2. Go to GH9083.
  3. Select Package Assembly.
  4. Select Add.
  5. On the Welcome screen select Next.
  6. Enter the Package name, Description and Pathcode, Select Next.
  7. If the package is using the Defaults then select End, otherwise you can use the form icons to perform the functions in this procedure.
  8. Activate the package.
  9. Select Define Build.
  10. On the Welcome screen select Next.
  11. Select Client and Server, select Next.
  12. Select the Client, select Next.
  13. Select End if you want to take the defaults.
  14. Activate the package.
  15. Select Submit Build to build the package.
  16. When the package build is complete, deploy the package to the client workstations or make it Approved for Install Manager for the client workstations.
