Skip Navigation Links
Exit Print View
Sun Dual 10 GbE PCIe 2.0 Fibre Channel Over Ethernet Software
User's Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Support and Accessibility
Understanding the FCoE Software
Installation Overview (Linux)
Installation Overview (Windows)
FCoE
System Requirements
OS Patches and Updates
Managing the Driver
Enabling the FCoE Software (Linux)
Enable FCoE During the Linux Installation
Enable FCoE After a Linux Installation
Set Up the Network Interfaces
Resolve SAN-Boot Errors (RHEL6.0/OL6.0)
Remove the FCoE Software Package (Linux)
Installing the FCoE Software (Windows)
Upgrade Guidelines for Software Release 15.4 (Windows)
Validation and Storage Certification
Hotfixes (Windows)
Download and Install the Driver (Windows)
Remove the Driver (Windows)
Verify the Functionality of the Network Interface
Booting Over a Network
Boot Over a 10GbE Network (Linux)
Set Up the FCoE Boot Option ROM (Windows)
Configuring the Switch
Configure the Cisco Nexus 5000 Series Switch
Configure the Brocade 8000 Series Switch
Configuring Driver Parameters (Linux)
Set Driver Parameters (Linux)
Driver Parameter Settings (Linux)
Configure Jumbo Frames (Linux)
Index
The ixgbe device driver controls the adapter's interfaces. You can manually set the ixgbe device driver parameters to customize each device in your system.
Description
Links
Configure the driver parameters for Linux.
Configure jumbo frames.
Related Information
