Skip Navigation Links
Exit Print View
Sun Quad Port GbE PCIe 2.0 ExpressModule, MMF
Product Notes
search filter icon
search icon
Document Information
1.  Important Information About the Sun Quad Port GbE PCIe 2.0 ExpressModule, MMF
Intel GbE Driver Support for Linux and Windows
Hardware and OS Software Support
Known Issues
Links Do Not Work Correctly After Running Oracle VTS and Internal Loopback Test Fails (CR 7147018 and CR 7008767)
Network Latency Under Oracle OpenSolaris Is Three Times Slower Than Solaris 10 5/09 (CR 6933376)
AER Multiple Corrected Errors
Related Documentation
Feedback
Support and Accessibility
Information on the Intel GbE drivers for Linux and Windows, including tools and documentation, is at the following web site:
http://www.intel.com/p/en_US/support/highlights/network/esa-i350-f4
