Skip Navigation Links
Exit Print View
Sun Dual Port 10GBase-T Adapter
Product Notes
search filter icon
search icon
Document Information
1.  Important Information About the Sun Dual Port 10GBase-T Adapter
Intel 10 GbE Driver Support for Linux and Windows
Hardware and OS Software Support
OS Patches and Updates
Known Issues
Sun Dual Port 10GBase-T Adapter Firmware Semaphore Acquire Mechanism Needs To Be Optimized in the ixgbe(7D) Driver (CR 7148426)
Links Do Not Work Correctly After Running Oracle VTS and Internal Loopback Test Fails (CR 7147018 and CR 7008767)
net0 Has No Link After Oracle Solaris svn_174 Boot From Port 0 (CR 7097919)
Creating Thousands of VLANs Runs the System Out of Memory (CR 7145327)
AER Multiple Corrected Errors (CR 7157354)
Sun Dual Port 10GBase-T Adapters Connected To Netgear JGS524 Switches Are Unable To Establish a Link (CR 7055438)
Related Documentation
Feedback
Support and Accessibility
Chapter 1
These product notes contain information about new features, known limitations, and documentation information for the Sun Dual Port 10GBase-T Adapter from Oracle.
New issues are added to the product notes as needed. Be sure to read the most recent version of the product notes that is available on the web. For the most recent version of the product notes, go to the Oracle documentation portal at the following site:
http://www.oracle.com/pls/topic/lookup?ctx=SDP_10GbE-PCIe2.0-LPA_BASE-T
Important: The Sun Dual Port 10GBase-T Adapter was formerly named the Sun Dual Port 10 GbE PCIe 2.0 Low Profile Adapter, Base-T. The former product name might still appear in the product and document. This product name change does not indicate any change in product features or functionality.
