Skip Navigation Links
Exit Print View
Sun Dual Port 10GBase-T ExpressModule
Product Notes
search filter icon
search icon
Document Information
1.  Important Information About the Sun Dual Port 10GBase-T ExpressModule
Intel 10 GbE Driver Support for Linux and Windows
Hardware and OS Software Support
OS Patches and Updates
Known Issues
Sun Dual Port 10GBase-T ExpressModule Firmware Semaphore Acquire Mechanism Needs To Be Optimized in the ixgbe(7D) Driver (CR 7148426)
Links Do Not Work Correctly After Running Oracle VTS and Internal Loopback Test Fails (CR 7147018 and CR 7008767)
net0 Has No Link After Oracle Solaris svn_174 Boot From Port 0 (CR 7097919)
Creating Thousands of VLANs Runs the System Out of Memory (CR 7145327)
AER Multiple Corrected Errors (CR 7157354)
Sun Dual Port 10GBase-T ExpressModule Connected To Netgear JGS524 Switches Are Unable To Establish a Link (CR 7055438)
Related Documentation
Feedback
Support and Accessibility
Description
Links
Access electronic support through My Oracle Support
Learn about Oracle’s commitment to accessibility
