Right-Click Menus
Use right-click menus to access context-sensitive commands in the console. Right-click menus contain commonly used commands for the object that is currently selected in Enterprise View, or commands that are specific to the active window in the workspace pane. Right-click menu options change dynamically, depending on where you are in the console or what you have selected in Enterprise View.
For example, select a database in Enterprise View, and then click the right mouse button to display a shortcut menu that contains commands that are relevant to databases.
You can configure mouse buttons in whatever order you choose. In this help system, the assumption is that the left mouse button is the primary button, and the right mouse button is the secondary button. Modify the procedures to access the menus according to your mouse configuration.
Related Information
