Skip Navigation Links
Exit Print View
Netra Blade X3-2B (formerly Sun Netra X6270 M3 Server Module)
Product Notes
search filter icon
search icon
Document Information
Using This Documentation
Getting the Newest Firmware and Software
Related Documentation
Support and Accessibility
Updates and Releases
Update Available
Firmware Release History
System Hardware and Software Features
Sun Netra 6000 Modular System
Supported Components with Legacy Chassis
Supported Components with New Chassis
Supported PCIe ExpressModules
FEMs and REMs Required for NEMs
Supported CPUs
Supported Memory
Supported Storage Drives
Supported Operating Systems
Server Update Information
Integrated Lights Out Manager (ILOM)
Hardware, Firmware, and BIOS Issues
Oracle ILOM restore_status Parameter Shows Partial Status (7167938)
Oracle ILOM 3.1 Might Not Support Clearing of Faults Diagnosed by Oracle Solaris Operating Systems (7170842)
Power Reset Event Entry in Oracle ILOM Log is Incorrect (7165042)
Unable to Change Serial Port Ownership Using BIOS Setup Utility (7168093)
New BIOS Boot Splash Screen
PXE-booting Fails When Using Cisco Switch (7149683)
Oracle Recommendations for Drive Slot Population and Virtual Drive Creation (7124194)
Blade With Solaris 10 8/11 Fails to Bring Up a Supported NEM After Hot Insertion (7121662)
UEFI Configuration Settings Might Be Lost When Transitioning Between UEFI and Legacy Boot Modes (7080526)
Physical Storage Drives Listed Twice on the Sun Netra 6000 Storage Module M2 (7116807)
Oracle System Assistant Issues
User Must Have Full Administrator Role Privileges to Update SP (7158820)
Some Operating Systems Do Not Mount the Oracle System Assistant USB Device
Oracle System Assistant Does Not Support Username “user”
The Virtual Ethernet Device is Reported as Not Installed in Windows 2008 (7129124)
Oracle System Assistant Cannot be Used to Update a Sun Storage 6 Gb SAS PCIe HBA From Legacy BIOS Firmware to UEFI BIOS Firmware (7123372)
“Path too Long” Errors When Unzipping Windows Downloads (7116803)
Popup Message Appears in the Oracle ILOM Web Interface When Launching Oracle System Assistant With the Launch Button (7126194)
Disks Might Not Appear During an Oracle System Assistant Installation of Windows 2008 R2 SP1 With an SG-SAS6–REM-Z and a Sun Netra 6000 Storage Module M2 (7152565)
Linux OS Issues
Oracle System Assistant Assisted-OS Installation of SLES 11 Might Prompt for Root Password (7158471)
Sense Key: Recovered Error messages can appear on the console and in /var/log/messages (7144197, 7158666)
Unable to Mount Oracle System Assistant USB Device on Some Versions of Linux
Oracle Linux and RHEL 6.1 grub.efi Cannot Be Used to Set Up a Network PXE Server for Booting UEFI Linux Clients (7095377)
Failure Occurs After Hot-Inserting a SAS-2 RAID Module (SGX-SAS6-EM-Z) (7088969)
Too Many PCI Cards or Modules Can Cause the System to Hang (6899040)
RHEL 6.1 kdump Does Not Work (7133869)
Oracle VM and VMware ESXi Issues
Oracle VM Current Issues
Unable to Mount Oracle System Assistant USB Device on Oracle VM 3.0.x (7149878)
Time of Date Incorrect on Oracle VM 3.0 (7061790)
VMware ESXi Issues
ESXi Cannot Mount the Oracle System Assistant USB Device (7154313)
Oracle Solaris OS Issues
Oracle Solaris Patch List
Oracle Solaris 10 and Solaris 11 OS Issues
Unable to Mount Oracle System Assistant USB Device on Oracle Solaris 10 8/11 OS
Server With Oracle Solaris 10 8/11 Fails to Bring Up hxge After Hot Insertion (7121662)
Xorg GUI Might Fail to Start With Certain Hardware Configurations Under Oracle Solaris 11 (7112301)
Getting Blade Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
The following table lists the released versions of the blade firmware.
Note - Oracle recommends that you upgrade to the latest system software release. This will ensure you have the latest supported firmware, BIOS, and drivers for your system.
System Software Release
Oracle ILOM SP Firmware
System BIOS
1.1 (r74415)
1.0.1 (r72433)
1.0 (r72433)
