Skip Navigation Links
Exit Print View
man pages section 9: DDI and DKI Kernel Functions     Oracle Solaris 10 1/13 Information Library
search filter icon
search icon
Document Information
Preface
Introduction
Kernel Functions for Drivers
adjmsg(9F)
allocb(9F)
allocb_tmpl(9F)
aminphys(9F)
anocancel(9F)
aphysio(9F)
ASSERT(9F)
assert(9F)
atomic_add_16(9F)
atomic_add_16_nv(9F)
atomic_add_32(9F)
atomic_add_32_nv(9F)
atomic_add_64(9F)
atomic_add_64_nv(9F)
atomic_add_8(9F)
atomic_add_8_nv(9F)
atomic_add(9F)
atomic_add_char(9F)
atomic_add_char_nv(9F)
atomic_add_int(9F)
atomic_add_int_nv(9F)
atomic_add_long(9F)
atomic_add_long_nv(9F)
atomic_add_ptr(9F)
atomic_add_ptr_nv(9F)
atomic_add_short(9F)
atomic_add_short_nv(9F)
atomic_and_16(9F)
atomic_and_16_nv(9F)
atomic_and_32(9F)
atomic_and_32_nv(9F)
atomic_and_64(9F)
atomic_and_64_nv(9F)
atomic_and_8(9F)
atomic_and_8_nv(9F)
atomic_and(9F)
atomic_and_uchar(9F)
atomic_and_uchar_nv(9F)
atomic_and_uint(9F)
atomic_and_uint_nv(9F)
atomic_and_ulong(9F)
atomic_and_ulong_nv(9F)
atomic_and_ushort(9F)
atomic_and_ushort_nv(9F)
atomic_bits(9F)
atomic_cas_16(9F)
atomic_cas_32(9F)
atomic_cas_64(9F)
atomic_cas_8(9F)
atomic_cas(9F)
atomic_cas_ptr(9F)
atomic_cas_uchar(9F)
atomic_cas_uint(9F)
atomic_cas_ulong(9F)
atomic_cas_ushort(9F)
atomic_clear_long_excl(9F)
atomic_dec_16(9F)
atomic_dec_16_nv(9F)
atomic_dec_32(9F)
atomic_dec_32_nv(9F)
atomic_dec_64(9F)
atomic_dec_64_nv(9F)
atomic_dec_8(9F)
atomic_dec_8_nv(9F)
atomic_dec(9F)
atomic_dec_ptr(9F)
atomic_dec_ptr_nv(9F)
atomic_dec_uchar(9F)
atomic_dec_uchar_nv(9F)
atomic_dec_uint(9F)
atomic_dec_uint_nv(9F)
atomic_dec_ulong(9F)
atomic_dec_ulong_nv(9F)
atomic_dec_ushort(9F)
atomic_dec_ushort_nv(9F)
atomic_inc_16(9F)
atomic_inc_16_nv(9F)
atomic_inc_32(9F)
atomic_inc_32_nv(9F)
atomic_inc_64(9F)
atomic_inc_64_nv(9F)
atomic_inc_8(9F)
atomic_inc_8_nv(9F)
atomic_inc(9F)
atomic_inc_ptr(9F)
atomic_inc_ptr_nv(9F)
atomic_inc_uchar(9F)
atomic_inc_uchar_nv(9F)
atomic_inc_uint(9F)
atomic_inc_uint_nv(9F)
atomic_inc_ulong(9F)
atomic_inc_ulong_nv(9F)
atomic_inc_ushort(9F)
atomic_inc_ushort_nv(9F)
atomic_ops(9F)
atomic_or_16(9F)
atomic_or_16_nv(9F)
atomic_or_32(9F)
atomic_or_32_nv(9F)
atomic_or_64(9F)
atomic_or_64_nv(9F)
atomic_or_8(9F)
atomic_or_8_nv(9F)
atomic_or(9F)
atomic_or_uchar(9F)
atomic_or_uchar_nv(9F)
atomic_or_uint(9F)
atomic_or_uint_nv(9F)
atomic_or_ulong(9F)
atomic_or_ulong_nv(9F)
atomic_or_ushort(9F)
atomic_or_ushort_nv(9F)
atomic_set_long_excl(9F)
atomic_swap_16(9F)
atomic_swap_32(9F)
atomic_swap_64(9F)
atomic_swap_8(9F)
atomic_swap(9F)
atomic_swap_ptr(9F)
atomic_swap_uchar(9F)
atomic_swap_uint(9F)
atomic_swap_ulong(9F)
atomic_swap_ushort(9F)
backq(9F)
bcanput(9F)
bcanputnext(9F)
bcmp(9F)
bcopy(9F)
bioclone(9F)
biodone(9F)
bioerror(9F)
biofini(9F)
bioinit(9F)
biomodified(9F)
bioreset(9F)
biosize(9F)
biowait(9F)
bp_copyin(9F)
bp_copyout(9F)
bp_mapin(9F)
bp_mapout(9F)
btop(9F)
btopr(9F)
bufcall(9F)
bzero(9F)
canput(9F)
canputnext(9F)
clrbuf(9F)
cmn_err(9F)
condvar(9F)
copyb(9F)
copyin(9F)
copymsg(9F)
copyout(9F)
crgetgid(9F)
crgetgroups(9F)
crgetngroups(9F)
crgetrgid(9F)
crgetruid(9F)
crgetsgid(9F)
crgetsuid(9F)
crgetuid(9F)
crgetzoneid(9F)
csx_AccessConfigurationRegister(9F)
csx_ConvertSize(9F)
csx_ConvertSpeed(9F)
csx_CS_DDI_Info(9F)
csx_DeregisterClient(9F)
csx_DupHandle(9F)
csx_Error2Text(9F)
csx_Event2Text(9F)
csx_FreeHandle(9F)
csx_Get16(9F)
csx_Get32(9F)
csx_Get64(9F)
csx_Get8(9F)
csx_GetEventMask(9F)
csx_GetFirstClient(9F)
csx_GetFirstTuple(9F)
csx_GetHandleOffset(9F)
csx_GetMappedAddr(9F)
csx_GetNextClient(9F)
csx_GetNextTuple(9F)
csx_GetStatus(9F)
csx_GetTupleData(9F)
csx_MakeDeviceNode(9F)
csx_MapLogSocket(9F)
csx_MapMemPage(9F)
csx_ModifyConfiguration(9F)
csx_ModifyWindow(9F)
csx_Parse_CISTPL_BATTERY(9F)
csx_Parse_CISTPL_BYTEORDER(9F)
csx_Parse_CISTPL_CFTABLE_ENTRY(9F)
csx_Parse_CISTPL_CONFIG(9F)
csx_Parse_CISTPL_DATE(9F)
csx_Parse_CISTPL_DEVICE(9F)
csx_Parse_CISTPL_DEVICE_A(9F)
csx_Parse_CISTPL_DEVICEGEO(9F)
csx_Parse_CISTPL_DEVICEGEO_A(9F)
csx_Parse_CISTPL_DEVICE_OA(9F)
csx_Parse_CISTPL_DEVICE_OC(9F)
csx_Parse_CISTPL_FORMAT(9F)
csx_Parse_CISTPL_FUNCE(9F)
csx_Parse_CISTPL_FUNCID(9F)
csx_Parse_CISTPL_GEOMETRY(9F)
csx_Parse_CISTPL_JEDEC_A(9F)
csx_Parse_CISTPL_JEDEC_C(9F)
csx_Parse_CISTPL_LINKTARGET(9F)
csx_Parse_CISTPL_LONGLINK_A(9F)
csx_Parse_CISTPL_LONGLINK_C(9F)
csx_Parse_CISTPL_LONGLINK_MFC(9F)
csx_Parse_CISTPL_MANFID(9F)
csx_Parse_CISTPL_ORG(9F)
csx_Parse_CISTPL_SPCL(9F)
csx_Parse_CISTPL_SWIL(9F)
csx_Parse_CISTPL_VERS_1(9F)
csx_Parse_CISTPL_VERS_2(9F)
csx_ParseTuple(9F)
csx_Put16(9F)
csx_Put32(9F)
csx_Put64(9F)
csx_Put8(9F)
csx_RegisterClient(9F)
csx_ReleaseConfiguration(9F)
csx_ReleaseIO(9F)
csx_ReleaseIRQ(9F)
csx_ReleaseSocketMask(9F)
csx_ReleaseWindow(9F)
csx_RemoveDeviceNode(9F)
csx_RepGet16(9F)
csx_RepGet32(9F)
csx_RepGet64(9F)
csx_RepGet8(9F)
csx_RepPut16(9F)
csx_RepPut32(9F)
csx_RepPut64(9F)
csx_RepPut8(9F)
csx_RequestConfiguration(9F)
csx_RequestIO(9F)
csx_RequestIRQ(9F)
csx_RequestSocketMask(9F)
csx_RequestWindow(9F)
csx_ResetFunction(9F)
csx_SetEventMask(9F)
csx_SetHandleOffset(9F)
csx_ValidateCIS(9F)
cv_broadcast(9F)
cv_destroy(9F)
cv_init(9F)
cv_signal(9F)
cv_timedwait(9F)
cv_timedwait_sig(9F)
cv_wait(9F)
cv_wait_sig(9F)
datamsg(9F)
DB_BASE(9F)
DB_LIM(9F)
DB_REF(9F)
DB_TYPE(9F)
ddi_add_event_handler(9F)
ddi_add_intr(9F)
ddi_add_softintr(9F)
ddi_binding_name(9F)
ddi_btop(9F)
ddi_btopr(9F)
ddi_can_receive_sig(9F)
ddi_cb_register(9F)
ddi_cb_unregister(9F)
ddi_check_acc_handle(9F)
ddi_check_dma_handle(9F)
ddi_copyin(9F)
ddi_copyout(9F)
ddi_create_minor_node(9F)
ddi_cred(9F)
ddi_device_copy(9F)
ddi_device_zero(9F)
ddi_devid_compare(9F)
ddi_devid_free(9F)
ddi_devid_get(9F)
ddi_devid_init(9F)
ddi_devid_register(9F)
ddi_devid_sizeof(9F)
ddi_devid_str_decode(9F)
ddi_devid_str_encode(9F)
ddi_devid_str_free(9F)
ddi_devid_unregister(9F)
ddi_devid_valid(9F)
ddi_dev_is_sid(9F)
ddi_devmap_segmap(9F)
ddi_dev_nintrs(9F)
ddi_dev_nregs(9F)
ddi_dev_regsize(9F)
ddi_dev_report_fault(9F)
ddi_dma_addr_bind_handle(9F)
ddi_dma_addr_setup(9F)
ddi_dma_alloc_handle(9F)
ddi_dma_buf_bind_handle(9F)
ddi_dma_buf_setup(9F)
ddi_dma_burstsizes(9F)
ddi_dma_coff(9F)
ddi_dma_curwin(9F)
ddi_dma_devalign(9F)
ddi_dmae_1stparty(9F)
ddi_dmae(9F)
ddi_dmae_alloc(9F)
ddi_dmae_disable(9F)
ddi_dmae_enable(9F)
ddi_dmae_getattr(9F)
ddi_dmae_getcnt(9F)
ddi_dmae_getlim(9F)
ddi_dmae_prog(9F)
ddi_dmae_release(9F)
ddi_dmae_stop(9F)
ddi_dma_free(9F)
ddi_dma_free_handle(9F)
ddi_dma_get_attr(9F)
ddi_dma_getwin(9F)
ddi_dma_htoc(9F)
ddi_dma_mem_alloc(9F)
ddi_dma_mem_free(9F)
ddi_dma_movwin(9F)
ddi_dma_nextcookie(9F)
ddi_dma_nextseg(9F)
ddi_dma_nextwin(9F)
ddi_dma_numwin(9F)
ddi_dma_segtocookie(9F)
ddi_dma_set_sbus64(9F)
ddi_dma_setup(9F)
ddi_dma_sync(9F)
ddi_dma_unbind_handle(9F)
ddi_driver_major(9F)
ddi_driver_name(9F)
ddi_enter_critical(9F)
ddi_exit_critical(9F)
ddi_ffs(9F)
ddi_fls(9F)
ddi_fm_acc_err_clear(9F)
ddi_fm_acc_err_get(9F)
ddi_fm_capable(9F)
ddi_fm_dma_err_clear(9F)
ddi_fm_dma_err_get(9F)
ddi_fm_ereport_post(9F)
ddi_fm_fini(9F)
ddi_fm_handler_register(9F)
ddi_fm_handler_unregister(9F)
ddi_fm_init(9F)
ddi_fm_service_impact(9F)
ddi_get16(9F)
ddi_get32(9F)
ddi_get64(9F)
ddi_get8(9F)
ddi_getb(9F)
ddi_get_cred(9F)
ddi_get_devstate(9F)
ddi_get_driver_private(9F)
ddi_get_eventcookie(9F)
ddi_get_iblock_cookie(9F)
ddi_getiminor(9F)
ddi_get_instance(9F)
ddi_get_kt_did(9F)
ddi_getl(9F)
ddi_get_lbolt64(9F)
ddi_get_lbolt(9F)
ddi_getll(9F)
ddi_getlongprop(9F)
ddi_getlongprop_buf(9F)
ddi_get_name(9F)
ddi_get_parent(9F)
ddi_get_pid(9F)
ddi_getprop(9F)
ddi_getproplen(9F)
ddi_get_soft_iblock_cookie(9F)
ddi_get_soft_state(9F)
ddi_get_time(9F)
ddi_getw(9F)
ddi_in_panic(9F)
ddi_intr_add_handler(9F)
ddi_intr_add_softint(9F)
ddi_intr_alloc(9F)
ddi_intr_block_disable(9F)
ddi_intr_block_enable(9F)
ddi_intr_clr_mask(9F)
ddi_intr_disable(9F)
ddi_intr_dup_handler(9F)
ddi_intr_enable(9F)
ddi_intr_free(9F)
ddi_intr_get_cap(9F)
ddi_intr_get_hilevel_pri(9F)
ddi_intr_get_navail(9F)
ddi_intr_get_nintrs(9F)
ddi_intr_get_pending(9F)
ddi_intr_get_pri(9F)
ddi_intr_get_softint_pri(9F)
ddi_intr_get_supported_types(9F)
ddi_intr_hilevel(9F)
ddi_intr_remove_handler(9F)
ddi_intr_remove_softint(9F)
ddi_intr_set_cap(9F)
ddi_intr_set_mask(9F)
ddi_intr_set_nreq(9F)
ddi_intr_set_pri(9F)
ddi_intr_set_softint_pri(9F)
ddi_intr_trigger_softint(9F)
ddi_io_get16(9F)
ddi_io_get32(9F)
ddi_io_get8(9F)
ddi_io_getb(9F)
ddi_io_getl(9F)
ddi_io_getw(9F)
ddi_iomin(9F)
ddi_iopb_alloc(9F)
ddi_iopb_free(9F)
ddi_io_put16(9F)
ddi_io_put32(9F)
ddi_io_put8(9F)
ddi_io_putb(9F)
ddi_io_putl(9F)
ddi_io_putw(9F)
ddi_io_rep_get16(9F)
ddi_io_rep_get32(9F)
ddi_io_rep_get8(9F)
ddi_io_rep_getb(9F)
ddi_io_rep_getl(9F)
ddi_io_rep_getw(9F)
ddi_io_rep_put16(9F)
ddi_io_rep_put32(9F)
ddi_io_rep_put8(9F)
ddi_io_rep_putb(9F)
ddi_io_rep_putl(9F)
ddi_io_rep_putw(9F)
ddi_log_sysevent(9F)
ddi_map_regs(9F)
ddi_mem_alloc(9F)
ddi_mem_free(9F)
ddi_mem_get16(9F)
ddi_mem_get32(9F)
ddi_mem_get64(9F)
ddi_mem_get8(9F)
ddi_mem_getb(9F)
ddi_mem_getl(9F)
ddi_mem_getll(9F)
ddi_mem_getw(9F)
ddi_mem_put16(9F)
ddi_mem_put32(9F)
ddi_mem_put64(9F)
ddi_mem_put8(9F)
ddi_mem_putb(9F)
ddi_mem_putl(9F)
ddi_mem_putll(9F)
ddi_mem_putw(9F)
ddi_mem_rep_get16(9F)
ddi_mem_rep_get32(9F)
ddi_mem_rep_get64(9F)
ddi_mem_rep_get8(9F)
ddi_mem_rep_getb(9F)
ddi_mem_rep_getl(9F)
ddi_mem_rep_getll(9F)
ddi_mem_rep_getw(9F)
ddi_mem_rep_put16(9F)
ddi_mem_rep_put32(9F)
ddi_mem_rep_put64(9F)
ddi_mem_rep_put8(9F)
ddi_mem_rep_putb(9F)
ddi_mem_rep_putl(9F)
ddi_mem_rep_putll(9F)
ddi_mem_rep_putw(9F)
ddi_mmap_get_model(9F)
ddi_model_convert_from(9F)
ddi_node_name(9F)
ddi_no_info(9F)
ddi_peek16(9F)
ddi_peek32(9F)
ddi_peek64(9F)
ddi_peek8(9F)
ddi_peek(9F)
ddi_peekc(9F)
ddi_peekd(9F)
ddi_peekl(9F)
ddi_peeks(9F)
ddi_periodic_add(9F)
ddi_periodic_delete(9F)
ddi_poke16(9F)
ddi_poke32(9F)
ddi_poke64(9F)
ddi_poke8(9F)
ddi_poke(9F)
ddi_pokec(9F)
ddi_poked(9F)
ddi_pokel(9F)
ddi_pokes(9F)
ddi_prop_create(9F)
ddi_prop_exists(9F)
ddi_prop_free(9F)
ddi_prop_get_int64(9F)
ddi_prop_get_int(9F)
ddi_prop_lookup(9F)
ddi_prop_lookup_byte_array(9F)
ddi_prop_lookup_int64_array(9F)
ddi_prop_lookup_int_array(9F)
ddi_prop_lookup_string(9F)
ddi_prop_lookup_string_array(9F)
ddi_prop_modify(9F)
ddi_prop_op(9F)
ddi_prop_remove(9F)
ddi_prop_remove_all(9F)
ddi_prop_undefine(9F)
ddi_prop_update(9F)
ddi_prop_update_byte_array(9F)
ddi_prop_update_int64(9F)
ddi_prop_update_int64_array(9F)
ddi_prop_update_int(9F)
ddi_prop_update_int_array(9F)
ddi_prop_update_string(9F)
ddi_prop_update_string_array(9F)
ddi_ptob(9F)
ddi_put16(9F)
ddi_put32(9F)
ddi_put64(9F)
ddi_put8(9F)
ddi_putb(9F)
ddi_putl(9F)
ddi_putll(9F)
ddi_putw(9F)
ddi_regs_map_free(9F)
ddi_regs_map_setup(9F)
ddi_remove_event_handler(9F)
ddi_remove_intr(9F)
ddi_remove_minor_node(9F)
ddi_remove_softintr(9F)
ddi_removing_power(9F)
ddi_rep_get16(9F)
ddi_rep_get32(9F)
ddi_rep_get64(9F)
ddi_rep_get8(9F)
ddi_rep_getb(9F)
ddi_rep_getl(9F)
ddi_rep_getll(9F)
ddi_rep_getw(9F)
ddi_report_dev(9F)
ddi_rep_put16(9F)
ddi_rep_put32(9F)
ddi_rep_put64(9F)
ddi_rep_put8(9F)
ddi_rep_putb(9F)
ddi_rep_putl(9F)
ddi_rep_putll(9F)
ddi_rep_putw(9F)
ddi_root_node(9F)
ddi_segmap(9F)
ddi_segmap_setup(9F)
ddi_set_driver_private(9F)
ddi_slaveonly(9F)
ddi_soft_state(9F)
ddi_soft_state_fini(9F)
ddi_soft_state_free(9F)
ddi_soft_state_init(9F)
ddi_soft_state_zalloc(9F)
ddi_strtol(9F)
ddi_strtoll(9F)
ddi_strtoul(9F)
ddi_strtoull(9F)
ddi_taskq_create(9F)
ddi_taskq_destroy(9F)
ddi_taskq_dispatch(9F)
ddi_taskq_resume(9F)
ddi_taskq_suspend(9F)
ddi_taskq_wait(9F)
ddi_trigger_softintr(9F)
ddi_umem_alloc(9F)
ddi_umem_free(9F)
ddi_umem_iosetup(9F)
ddi_umem_lock(9F)
ddi_umem_unlock(9F)
ddi_unmap_regs(9F)
delay(9F)
desballoc(9F)
devmap_default_access(9F)
devmap_devmem_setup(9F)
devmap_do_ctxmgt(9F)
devmap_load(9F)
devmap_set_ctx_timeout(9F)
devmap_setup(9F)
devmap_umem_setup(9F)
devmap_unload(9F)
disksort(9F)
dlbindack(9F)
dlerrorack(9F)
dlokack(9F)
dlphysaddrack(9F)
dluderrorind(9F)
drv_getparm(9F)
drv_hztousec(9F)
drv_priv(9F)
drv_usectohz(9F)
drv_usecwait(9F)
dupb(9F)
dupmsg(9F)
enableok(9F)
esballoc(9F)
esbbcall(9F)
flushband(9F)
flushq(9F)
freeb(9F)
freemsg(9F)
free_pktiopb(9F)
freerbuf(9F)
freezestr(9F)
geterror(9F)
gethrtime(9F)
getmajor(9F)
getminor(9F)
get_pktiopb(9F)
getq(9F)
getrbuf(9F)
gld(9F)
gld_intr(9F)
gld_mac_alloc(9F)
gld_mac_free(9F)
gld_recv(9F)
gld_register(9F)
gld_sched(9F)
gld_unregister(9F)
hat_getkpfnum(9F)
hook_alloc(9F)
hook_free(9F)
id32_alloc(9F)
id32_free(9F)
id32_lookup(9F)
inb(9F)
inl(9F)
insq(9F)
inw(9F)
IOC_CONVERT_FROM(9F)
kmem_alloc(9F)
kmem_cache_alloc(9F)
kmem_cache_create(9F)
kmem_cache_destroy(9F)
kmem_cache_free(9F)
kmem_free(9F)
kmem_zalloc(9F)
kstat_create(9F)
kstat_delete(9F)
kstat_install(9F)
kstat_named_init(9F)
kstat_named_setstr(9F)
kstat_queue(9F)
kstat_runq_back_to_waitq(9F)
kstat_runq_enter(9F)
kstat_runq_exit(9F)
kstat_waitq_enter(9F)
kstat_waitq_exit(9F)
kstat_waitq_to_runq(9F)
ldi_add_event_handler(9F)
ldi_aread(9F)
ldi_awrite(9F)
ldi_close(9F)
ldi_devmap(9F)
ldi_dump(9F)
ldi_get_dev(9F)
ldi_get_devid(9F)
ldi_get_eventcookie(9F)
ldi_get_minor_name(9F)
ldi_getmsg(9F)
ldi_get_otyp(9F)
ldi_get_size(9F)
ldi_ident_from_dev(9F)
ldi_ident_from_dip(9F)
ldi_ident_from_stream(9F)
ldi_ident_release(9F)
ldi_ioctl(9F)
ldi_open_by_dev(9F)
ldi_open_by_devid(9F)
ldi_open_by_name(9F)
ldi_poll(9F)
ldi_prop_exists(9F)
ldi_prop_get_int64(9F)
ldi_prop_get_int(9F)
ldi_prop_lookup_byte_array(9F)
ldi_prop_lookup_int64_array(9F)
ldi_prop_lookup_int_array(9F)
ldi_prop_lookup_string(9F)
ldi_prop_lookup_string_array(9F)
ldi_putmsg(9F)
ldi_read(9F)
ldi_remove_event_handler(9F)
ldi_strategy(9F)
ldi_write(9F)
linkb(9F)
mac(9F)
mac_alloc(9F)
mac_fini_ops(9F)
mac_free(9F)
mac_hcksum_get(9F)
mac_hcksum_set(9F)
mac_init_ops(9F)
mac_link_update(9F)
mac_lso_get(9F)
mac_prop_info_set_default_link_flowctrl(9F)
mac_prop_info_set_default_str(9F)
mac_prop_info_set_default_uint8(9F)
mac_prop_info_set_perm(9F)
mac_prop_info_set_range_uint32(9F)
mac_register(9F)
mac_rx(9F)
mac_tx_update(9F)
mac_unregister(9F)
makecom(9F)
makecom_g0(9F)
makecom_g0_s(9F)
makecom_g1(9F)
makecom_g5(9F)
makedevice(9F)
max(9F)
MBLKHEAD(9F)
MBLKIN(9F)
MBLKL(9F)
MBLKSIZE(9F)
MBLKTAIL(9F)
mcopyin(9F)
mcopymsg(9F)
mcopyout(9F)
membar_consumer(9F)
membar_enter(9F)
membar_exit(9F)
membar_ops(9F)
membar_producer(9F)
memchr(9F)
memcmp(9F)
memcpy(9F)
memmove(9F)
memset(9F)
merror(9F)
mexchange(9F)
min(9F)
minphys(9F)
mioc2ack(9F)
miocack(9F)
miocnak(9F)
miocpullup(9F)
mkiocb(9F)
mod_info(9F)
mod_install(9F)
mod_remove(9F)
msgdsize(9F)
msgpullup(9F)
msgsize(9F)
mt-streams(9F)
mutex(9F)
mutex_destroy(9F)
mutex_enter(9F)
mutex_exit(9F)
mutex_init(9F)
mutex_owned(9F)
mutex_tryenter(9F)
net_event_notify_register(9F)
net_event_notify_unregister(9F)
net_getifname(9F)
net_getlifaddr(9F)
net_getmtu(9F)
net_getnetid(9F)
net_getpmtuenabled(9F)
net_hook_register(9F)
net_hook_unregister(9F)
netinfo(9F)
net_inject(9F)
net_inject_alloc(9F)
net_inject_free(9F)
net_instance_alloc(9F)
net_instance_free(9F)
net_instance_notify_register(9F)
net_instance_notify_unregister(9F)
net_instance_protocol_unregister(9F)
net_instance_register(9F)
net_instance_unregister(9F)
net_ispartialchecksum(9F)
net_isvalidchecksum(9F)
net_kstat_create(9F)
net_kstat_delete(9F)
net_lifgetnext(9F)
net_netidtozonid(9F)
net_phygetnext(9F)
net_phylookup(9F)
net_protocol_lookup(9F)
net_protocol_notify_register(9F)
net_protocol_release(9F)
net_protocol_walk(9F)
net_routeto(9F)
net_zoneidtonetid(9F)
nochpoll(9F)
nodev(9F)
noenable(9F)
nulldev(9F)
numtos(9F)
nv_alloc_fini(9F)
nv_alloc_init(9F)
nvlist_add_boolean(9F)
nvlist_add_boolean_array(9F)
nvlist_add_boolean_value(9F)
nvlist_add_byte(9F)
nvlist_add_byte_array(9F)
nvlist_add_int16(9F)
nvlist_add_int16_array(9F)
nvlist_add_int32(9F)
nvlist_add_int32_array(9F)
nvlist_add_int64(9F)
nvlist_add_int64_array(9F)
nvlist_add_int8(9F)
nvlist_add_int8_array(9F)
nvlist_add_nvlist(9F)
nvlist_add_nvlist_array(9F)
nvlist_add_nvpair(9F)
nvlist_add_string(9F)
nvlist_add_string_array(9F)
nvlist_add_uint16(9F)
nvlist_add_uint16_array(9F)
nvlist_add_uint32(9F)
nvlist_add_uint32_array(9F)
nvlist_add_uint64(9F)
nvlist_add_uint64_array(9F)
nvlist_add_uint8(9F)
nvlist_add_uint8_array(9F)
nvlist_alloc(9F)
nvlist_dup(9F)
nvlist_free(9F)
nvlist_lookup_boolean(9F)
nvlist_lookup_boolean_array(9F)
nvlist_lookup_boolean_value(9F)
nvlist_lookup_byte(9F)
nvlist_lookup_byte_array(9F)
nvlist_lookup_int16(9F)
nvlist_lookup_int16_array(9F)
nvlist_lookup_int32(9F)
nvlist_lookup_int32_array(9F)
nvlist_lookup_int64(9F)
nvlist_lookup_int64_array(9F)
nvlist_lookup_int8(9F)
nvlist_lookup_int8_array(9F)
nvlist_lookup_nvlist(9F)
nvlist_lookup_nvlist_array(9F)
nvlist_lookup_pairs(9F)
nvlist_lookup_string(9F)
nvlist_lookup_string_array(9F)
nvlist_lookup_uint16(9F)
nvlist_lookup_uint16_array(9F)
nvlist_lookup_uint32(9F)
nvlist_lookup_uint32_array(9F)
nvlist_lookup_uint64(9F)
nvlist_lookup_uint64_array(9F)
nvlist_lookup_uint8(9F)
nvlist_lookup_uint8_array(9F)
nvlist_merge(9F)
nvlist_next_nvpair(9F)
nvlist_pack(9F)
nvlist_remove(9F)
nvlist_remove_all(9F)
nvlist_size(9F)
nvlist_t(9F)
nvlist_unpack(9F)
nvlist_xalloc(9F)
nvlist_xdup(9F)
nvlist_xpack(9F)
nvlist_xunpack(9F)
nvpair_name(9F)
nvpair_type(9F)
nvpair_value_boolean_array(9F)
nvpair_value_byte(9F)
nvpair_value_byte_array(9F)
nvpair_value_int16(9F)
nvpair_value_int16_array(9F)
nvpair_value_int32(9F)
nvpair_value_int32_array(9F)
nvpair_value_int64(9F)
nvpair_value_int64_array(9F)
nvpair_value_int8(9F)
nvpair_value_int8_array(9F)
nvpair_value_nvlist(9F)
nvpair_value_nvlist_array(9F)
nvpair_value_string(9F)
nvpair_value_string_array(9F)
nvpair_value_uint16(9F)
nvpair_value_uint16_array(9F)
nvpair_value_uint32(9F)
nvpair_value_uint32_array(9F)
nvpair_value_uint64(9F)
nvpair_value_uint64_array(9F)
nvpair_value_uint8(9F)
nvpair_value_uint8_array(9F)
OTHERQ(9F)
otherq(9F)
outb(9F)
outl(9F)
outw(9F)
pci_config_get16(9F)
pci_config_get32(9F)
pci_config_get64(9F)
pci_config_get8(9F)
pci_config_getb(9F)
pci_config_getl(9F)
pci_config_getll(9F)
pci_config_getw(9F)
pci_config_put16(9F)
pci_config_put32(9F)
pci_config_put64(9F)
pci_config_put8(9F)
pci_config_putb(9F)
pci_config_putl(9F)
pci_config_putll(9F)
pci_config_putw(9F)
pci_config_setup(9F)
pci_config_teardown(9F)
pci_ereport_post(9F)
pci_ereport_setup(9F)
pci_ereport_teardown(9F)
pci_param_free(9F)
pci_param_get(9F)
pci_param_get_ioctl(9F)
pci_plist_get(9F)
pci_plist_getvf(9F)
pci_plist_lookup(9F)
pci_plist_lookup_int16(9F)
pci_plist_lookup_int16_array(9F)
pci_plist_lookup_int32(9F)
pci_plist_lookup_int32_array(9F)
pci_plist_lookup_int64(9F)
pci_plist_lookup_int64_array(9F)
pci_plist_lookup_int8(9F)
pci_plist_lookup_int8_array(9F)
pci_plist_lookup_plist(9F)
pci_plist_lookup_string(9F)
pci_plist_lookup_string_array(9F)
pci_plist_lookup_uint16(9F)
pci_plist_lookup_uint16_array(9F)
pci_plist_lookup_uint32(9F)
pci_plist_lookup_uint32_array(9F)
pci_plist_lookup_uint64(9F)
pci_plist_lookup_uint64_array(9F)
pci_plist_lookup_uint8(9F)
pci_plist_lookup_uint8_array(9F)
pci_report_pmcap(9F)
pci_restore_config_regs(9F)
pci_save_config_regs(9F)
pciv_send(9F)
pciv_vf_config(9F)
physio(9F)
pm_busy_component(9F)
pm_idle_component(9F)
pm_lower_power(9F)
pm_power_has_changed(9F)
pm_raise_power(9F)
pm_trans_check(9F)
pollwakeup(9F)
priv_getbyname(9F)
priv_policy(9F)
priv_policy_choice(9F)
priv_policy_only(9F)
proc_ref(9F)
proc_signal(9F)
proc_unref(9F)
ptob(9F)
pullupmsg(9F)
put(9F)
putbq(9F)
putctl1(9F)
putctl(9F)
putnext(9F)
putnextctl1(9F)
putnextctl(9F)
putq(9F)
qassociate(9F)
qbufcall(9F)
qenable(9F)
qprocsoff(9F)
qprocson(9F)
qreply(9F)
qsize(9F)
qtimeout(9F)
qunbufcall(9F)
quntimeout(9F)
qwait(9F)
qwait_sig(9F)
qwriter(9F)
RD(9F)
rd(9F)
repinsb(9F)
repinsd(9F)
repinsw(9F)
repoutsb(9F)
repoutsd(9F)
repoutsw(9F)
rmalloc(9F)
rmallocmap(9F)
rmallocmap_wait(9F)
rmalloc_wait(9F)
rmfree(9F)
rmfreemap(9F)
rmvb(9F)
rmvq(9F)
rw_destroy(9F)
rw_downgrade(9F)
rw_enter(9F)
rw_exit(9F)
rw_init(9F)
rwlock(9F)
rw_read_locked(9F)
rw_tryenter(9F)
rw_tryupgrade(9F)
SAMESTR(9F)
samestr(9F)
scsi_abort(9F)
scsi_alloc_consistent_buf(9F)
scsi_cname(9F)
scsi_destroy_pkt(9F)
scsi_dmafree(9F)
scsi_dmaget(9F)
scsi_dname(9F)
scsi_errmsg(9F)
scsi_ext_sense_fields(9F)
scsi_find_sense_descr(9F)
scsi_free_consistent_buf(9F)
scsi_get_device_type_scsi_options(9F)
scsi_hba_attach(9F)
scsi_hba_attach_setup(9F)
scsi_hba_detach(9F)
scsi_hba_fini(9F)
scsi_hba_init(9F)
scsi_hba_lookup_capstr(9F)
scsi_hba_pkt_alloc(9F)
scsi_hba_pkt_comp(9F)
scsi_hba_pkt_free(9F)
scsi_hba_probe(9F)
scsi_hba_tran_alloc(9F)
scsi_hba_tran_free(9F)
scsi_ifgetcap(9F)
scsi_ifsetcap(9F)
scsi_init_pkt(9F)
scsi_log(9F)
scsi_mname(9F)
scsi_pktalloc(9F)
scsi_pktfree(9F)
scsi_poll(9F)
scsi_probe(9F)
scsi_resalloc(9F)
scsi_reset(9F)
scsi_reset_notify(9F)
scsi_resfree(9F)
scsi_rname(9F)
scsi_sense_asc(9F)
scsi_sense_ascq(9F)
scsi_sense_cmdspecific_uint64(9F)
scsi_sense_info_uint64(9F)
scsi_sense_key(9F)
scsi_setup_cdb(9F)
scsi_slave(9F)
scsi_sname(9F)
scsi_sync_pkt(9F)
scsi_transport(9F)
scsi_unprobe(9F)
scsi_unslave(9F)
scsi_validate_sense(9F)
scsi_vu_errmsg(9F)
sema_destroy(9F)
sema_init(9F)
sema_p(9F)
semaphore(9F)
sema_p_sig(9F)
sema_tryp(9F)
sema_v(9F)
SIZEOF_PTR(9F)
SIZEOF_STRUCT(9F)
snprintf(9F)
sprintf(9F)
stoi(9F)
strcasecmp(9F)
strchr(9F)
strcmp(9F)
strcpy(9F)
strlcat(9F)
strlcpy(9F)
strlen(9F)
strlog(9F)
strncasecmp(9F)
strncat(9F)
strncmp(9F)
strncpy(9F)
strqget(9F)
strqset(9F)
strrchr(9F)
strspn(9F)
STRUCT_BUF(9F)
STRUCT_DECL(9F)
STRUCT_FADDR(9F)
STRUCT_FGET(9F)
STRUCT_FGETP(9F)
STRUCT_FSET(9F)
STRUCT_FSETP(9F)
STRUCT_HANDLE(9F)
STRUCT_INIT(9F)
STRUCT_SET_HANDLE(9F)
STRUCT_SIZE(9F)
swab(9F)
taskq(9F)
taskq_suspended(9F)
testb(9F)
timeout(9F)
u8_strcmp(9F)
u8_textprep_str(9F)
u8_validate(9F)
uconv_u16tou32(9F)
uconv_u16tou8(9F)
uconv_u32tou16(9F)
uconv_u32tou8(9F)
uconv_u8tou16(9F)
uconv_u8tou32(9F)
uiomove(9F)
unbufcall(9F)
unfreezestr(9F)
unlinkb(9F)
untimeout(9F)
ureadc(9F)
usb_alloc_bulk_req(9F)
usb_alloc_ctrl_req(9F)
usb_alloc_intr_req(9F)
usb_alloc_isoc_req(9F)
usb_alloc_request(9F)
usb_client_attach(9F)
usb_client_detach(9F)
usb_clr_feature(9F)
usb_create_pm_components(9F)
usb_free_bulk_req(9F)
usb_free_ctrl_req(9F)
usb_free_descr_tree(9F)
usb_free_dev_data(9F)
usb_free_intr_req(9F)
usb_free_isoc_req(9F)
usb_get_addr(9F)
usb_get_alt_if(9F)
usb_get_cfg(9F)
usb_get_current_frame_number(9F)
usb_get_dev_data(9F)
usb_get_if_number(9F)
usb_get_max_pkts_per_isoc_request(9F)
usb_get_status(9F)
usb_get_string_descr(9F)
usb_handle_remote_wakeup(9F)
usb_lookup_ep_data(9F)
usb_owns_device(9F)
usb_parse_data(9F)
usb_pipe_bulk_xfer(9F)
usb_pipe_close(9F)
usb_pipe_ctrl_xfer(9F)
usb_pipe_ctrl_xfer_wait(9F)
usb_pipe_drain_reqs(9F)
usb_pipe_get_max_bulk_transfer_size(9F)
usb_pipe_get_private(9F)
usb_pipe_get_state(9F)
usb_pipe_intr_xfer(9F)
usb_pipe_isoc_xfer(9F)
usb_pipe_open(9F)
usb_pipe_reset(9F)
usb_pipe_set_private(9F)
usb_pipe_stop_intr_polling(9F)
usb_pipe_stop_isoc_polling(9F)
usb_print_descr_tree(9F)
usb_register_hotplug_cbs(9F)
usb_set_alt_if(9F)
usb_set_cfg(9F)
usb_unregister_hotplug_cbs(9F)
uwritec(9F)
va_arg(9F)
va_copy(9F)
va_end(9F)
va_start(9F)
vcmn_err(9F)
vsprintf(9F)
WR(9F)
wr(9F)
zcmn_err(9F)
max
- return the larger of two integers
Synopsis
#include <sys/ddi.h>
int max(int int1, int int2);
Interface Level
Architecture independent level 1 (DDI/DKI).
Parameters
int1
The first integer.
int2
The second integer.
Description
The max() function compares two signed integers and returns the larger of the two.
Return Values
The larger of the two numbers.
Context
The max() function can be called from user, interrupt, or kernel context.
See Also
min(9F)
Writing Device Drivers
