Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
V1 and V2c Protocol Command Format
Display the Date and Time (SNMP)
Display the Aggregate Sensors State (SNMP)
Display Power Supply Status (SNMP)
Display Board-Level Voltages (SNMP)
Display Internal Temperatures (SNMP)
Display the Sensor Alarm State (SNMP)
Display Oracle ILOM Sessions (SNMP)
Display the Oracle ILOM Event Log (SNMP)
Checking the Status of Services (SNMP)
Display the HTTP Service Status (SNMP)
Display the HTTPS Service Status (SNMP)
Display the DNS Client Status (SNMP)
Display the SMTP Client Status (SNMP)
Display the NTP Servers (SNMP)
Verifying Other Aspects With Oracle ILOM (SNMP)
Display the Alert Properties (SNMP)
Display Oracle ILOM User Accounts (SNMP)
Display the Remote Log Hosts (SNMP)
Display the Network Management Configuration (SNMP)
Display Power Supply FRU ID (SNMP)
Display the System Components (SNMP)
Display the Additional System Component Information (SNMP)
Display the Firmware Version (SNMP)
Display System Identification Properties (SNMP)
Performing General Tasks (SNMP)
Set the Network Time Protocol State (SNMP)
Set the Network Time Protocol Servers (SNMP)
Clear the Oracle ILOM Event Log (SNMP)
Set the Remote Log Hosts (SNMP)
Configure the DNS Client (SNMP)
Configure the SMTP Client (SNMP)
Set the Network Parameters (SNMP)
Set the System Identification Properties (SNMP)
Add an Oracle ILOM User Account (SNMP)
Delete an Oracle ILOM User Account (SNMP)
Managing Other Aspects With Oracle ILOM (SNMP)
Set the HTTP Service State (SNMP)
Set the HTTPS Service State (SNMP)
Enable Alerts to Send SNMP Traps (SNMP)
Enable Alerts to Send PETs (SNMP)
Enable Alerts to Send Email Alerts (SNMP)
Modify Alert SNMP Version (SNMP)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Note - The entity numbers used in this procedure are for example only. Your entity numbers might differ, depending on the switch firmware and configuration. For more information about entity numbers, see Display the Entity Numbers.
Note - The fan speed values displayed for this procedure are in RPM.
$ snmpget -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatDiscreteSensorCurrent.number
where number is is the entity number for the /SYS/FANx/PRSNT presence sensor target for the respective fan. This example uses entity number 43 for the left fan (FAN1):
$ snmpget -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatDiscreteSensorCurrent.43 SUN-PLATFORM-MIB::sunPlatDiscreteSensorCurrent.43 = INTEGER: 2 $
In the output, the INTEGER: 2 means the fan is present. INTEGER: 1 means the fan is not present.
$ snmpget -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.number
where number is is the entity number for the /SYS/FANx/TACH speed sensor target for the respective fan. This example uses entity number 44 for the left fan (FAN1):
$ snmpget -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.44 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.44 = INTEGER: 12099 $
The FAN1 speed displayed in the output of the example is 12099 RPM.
Note - Fan speed readings can vary and are influenced by the switch environment and loading.
$ snmpwalk -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorTable SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.4 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.6 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.7 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.8 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.10 = INTEGER: volts(6) . . . SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.44 = INTEGER: rpm(20) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.47 = INTEGER: rpm(20) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.50 = INTEGER: rpm(20) . . . SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.44 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.47 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.50 = INTEGER: 0 . . . SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.44 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.47 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.50 = INTEGER: none(1) . . . SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.44 = INTEGER: 12208 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.47 = INTEGER: 11772 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.50 = INTEGER: 12099 . . . SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.44 = INTEGER: reset(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.47 = INTEGER: reset(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.50 = INTEGER: reset(1) $
You can also filter the output of the snmpwalk command for a specific entity number. This is an example of filtering the snmpwalk command output.:
$ snmpwalk -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorTable |grep -F ’.number =’
where number is the entity number.
Note - The manner in which you can filter the output varies according to your operating system.
To filter speed information for the left fan (FAN1), use the entity number respective to the /SYS/FAN1/TACH speed sensor target. This filtering example uses entity number 44:
$ snmpwalk -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorTable |grep -F ’.44 =’ SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.44 = INTEGER: rpm(20) SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.44 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.44 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.44 = INTEGER: 12208 SUN-PLATFORM-MIB::sunPlatNumericSensorNormalMin.44 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorNormalMax.44 = INTEGER: 255 SUN-PLATFORM-MIB::sunPlatNumericSensorAccuracy.44 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorLowerThresholdNonCritical.44 = INTEGER: 6322 SUN-PLATFORM-MIB::sunPlatNumericSensorUpperThresholdNonCritical.44 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorLowerThresholdCritical.44 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorUpperThresholdCritical.44 = INTEGER: 26705 SUN-PLATFORM-MIB::sunPlatNumericSensorLowerThresholdFatal.44 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorUpperThresholdFatal.44 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorHysteresis.44 = Gauge32: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorEnabledThresholds.44 = BITS: 90 lowerThresholdNonCritical(0) upperThresholdCritical(3) SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.44 = INTEGER: reset(1) $
