Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
InfiniBand Connector Status Window
Gateway Connector Status Window
InfiniBand Connector Parameters and Status
Gateway Connector Parameters and Status
I4 to Gateway Interface Parameters and Status
I4 Switch Chip Port Parameters and Status
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
This figure provides an example of the rear panel diagram.
The rear panel diagram displays the presence of connectors and their status within a mockup of the gateway rear panel. The diagram displays the management controller’s IP address, and the connector receptacles and their respective connector names. When a cable is attached to a receptacle, a connection is made. That connection is displayed in the diagram as a gray rectangle, with three or four smaller indicators. Moving the mouse cursor over an indicator, clicking on an indicator, or clicking on a connection opens a window that provides additional information about that indicator or connection.
