Skip Navigation Links
Exit Print View
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Support and Accessibility
Understanding the Gateway
Gateway Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
Network Management Connector and Pins
Data QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding Data Cabling
Preparing to Install the Gateway
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Ethernet Splitter Data Cables
Route the Data Cables
Installing the Gateway
Install the Gateway in the Rack
Powering On the Gateway
Connecting Data cables
Troubleshooting the Gateway
Gateway Hardware Problems
InfiniBand Fabric Problems
Identifying LEDs
Understanding Routing Through the Gateway
Switch GUIDs Overview
Configuration Overview
Hardware Command Overview
InfiniBand Command Overview
ILOM Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Identify All Switches in the Fabric
Identify All HCAs in the Fabric
Display the InfiniBand Fabric Topology (Simple)
Display the InfiniBand Fabric Topology (Detailed)
Display a Route Through the Fabric
Display the Link Status of a Node
Display Counters for a Node
Display Low-Level Detailed Information About a Node
Display Low-Level Detailed Information About a Port
Display the InfiniBand Fabric Partition Configuration
Display the InfiniBand Fabric Configuration
Perform Comprehensive Diagnostics for the Entire Fabric
Determine Changes to the InfiniBand Fabric Topology
Find 1x, SDR, or DDR Links in the Fabric
Determine Which Links Are Experiencing Significant Errors
Clear Data and Error Counters
Reset a Port
Set Port Speed
Disable a Port
Enable a Port
Configuring the Fabric Director Node List
Fabric Director and Fabric Elements
fdconfig Command
Create a Fabric Configuration
Add or Remove an Element From the Fabric Configuration
Modify an Element of the Fabric Configuration
Exchange Master Fabric Director Status
Partitioning the InfiniBand Fabric
smpartition Command
Remove User Partitions for Firmware Downgrade
Use the smnodes Command
Determine Partitions and P_Keys
Create a User Partition
Add or Remove a Port From a Partition
Modify a Partition or Port
Delete a Partition
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Monitoring Gateway Resources
Controlling LAGs
Controlling VLANs and VNICs
Controlling Gateway Ports and Parameters
Remote Management
Understanding Oracle ILOM on the Gateway
Oracle ILOM Overview
Supported Features
CLI Overview
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Gateway Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Gateway Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (ILOM)
help Command (ILOM)
load Command
reset Command
set Command
show Command
version Command (ILOM)
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing Data Cables
Inspecting the Data Cables
Remove a Data Cable
Install a Data Cable
Servicing the Battery
Remove the Gateway From the Rack
Replace the Battery
addlagport Command
allowhostconfig Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
createlag Command
createvlan Command
createvnic Command
dcsport Command
deletelag Command
deletevlan Command
deletevnic Command
dellagport Command
disablecablelog Command
disablegwport Command
disablelagmode Command
disablelinklog Command
disablesm Command
disableswitchport Command
disablevnic Command
disallowhostconfig Command
enablecablelog Command
enablegwport Command
enablelagmode Command
enablelinklog Command
enablesm Command
enableswitchport Command
enablevnic Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
matchtopology Command
setcontrolledhandover Command
setdefaultgwdiscpkey Command
setgwethport Command
setgwinstance Command
setgwsl Command
setgwsystemname Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsubnetprefix Command
showfruinfo Command
showgwconfig Command
showgwports Command
showlag Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
showvlan Command
showvnics Command
smconfigtest Command
smnodes Command
smpartition Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
Similar to the ibswitches command, the ibhosts command displays identity information about the HCAs in the InfiniBand fabric. The output contains the GUID and name for each HCA.
Note - Unlike the ibswitches command, the ibhosts command does not display the LIDs.
  1. On the management controller, type.
    Note - The output in the example is just a portion of the full output and varies for each InfiniBand topology.
    # ibhosts
    Ca      : 0x00212856cd22c000 ports 2 "SUN IB QDR GW switch mnm34-97 Bridge 0"
    Ca      : 0x00212856cd22c040 ports 2 "SUN IB QDR GW switch mnm34-97 Bridge 1"
    Ca      : 0x0002c903000891aa ports 2 "mnm34-54 HCA-1"
    Ca      : 0x00212800013ece9e ports 2 "mnm34-55 HCA-1"
    Ca      : 0x0003ba000100e370 ports 2 "mnm34-60 HCA-1"
  2. (Optional) Save the output of ibhosts command as a text file named hostGUIDs.txt.
Related Information
