Skip Navigation Links
Exit Print View
Sun ZFS Storage 7120, 7320, and 7420 Appliance Customer Service Manual
search filter icon
search icon
Document Information
Preface
1.  Introduction
2.  Hardware Maintenance
3.  System Maintenance
System
Introduction
System Disks
Support Bundles
Managing Support Bundles Using the BUI
Managing Support Bundles Using the CLI
Initial Setup
Factory Reset
Updates
System Updates
Procedure Overview
Preconditions
Update Health Checks
BUI
CLI
Troubleshooting Update Health Check Failures
Actions to Take to Resolve Health Check Alerts
Deferred Updates
Reboot After an Update
Hardware Firmware Updates
Rollback
Fail-safe Rollback
Cluster Upgrade
Updating via the BUI
Unpacking and Verifying Media
Beginning an Upgrade
Rolling Back
Removing Update Media
Applying Deferred Updates
Updating via the CLI
Rolling Back
Passthrough x
Passthrough-x Deferred Update
User Quotas
User Quotas Deferred Update
COMSTAR
COMSTAR Deferred Update
Triple Parity RAID
Triple-Parity RAID Deferred Update
Dedup
Data Deduplication Deferred Update
Replication
Replication Deferred Update
Received Properties
Received Properties Deferred Update
Slim ZIL
Introduction
Snapshot Deletion
Snapshot Deletion Deferred Update
Recursive Snapshots
Recursive Snapshots Deferred Update
Multi Replace
Multi Replace Deferred Update
RAIDZ Mirror
RAIDZ/Mirror Deferred Update
Optional Child Dir
Introduction
ConfigurationBackup
Configuration Backup
Backup Contents
Restore Impact
Security Considerations
Managing Configuration Backups Using the BUI
Create a Configuration Backup
Restore from a Saved Configuration
Delete a Saved Configuration
Export a Saved Configuration
Import a Saved Configuration
Managing Configuration Backups Using the CLI
Listing Configurations
Problems
Problems
Active problems display
Repairing problems
Related features
Logs
Introduction
Alerts
Faults
System
Audit
Phone Home
BUI
CLI
Listing logs
Viewing a log
Entry details
Glossary
System
Introduction
The Maintenance > System screen provides several system-level features. The screen allows the administrator to:
System Disks
The system disks section shows the status of the system disks, and their current usage. The BUI displays this with a pie-chart, and the CLI as a text list. For example:
tarpon:> maintenance system disks show
Properties:
                       profile = mirror
                          root = 1.14G
                           var = 52.4M
                        update = 2.52M
                         stash = 14.8M
                          dump = 16.0G
                         cores = 18K
                       unknown = 39.0G
                          free = 401G
Disks:
DISK        LABEL      STATE
disk-000    HDD 7      healthy
disk-001    HDD 6      healthy
Note: The "disk" column is not required by the GUI.
Support Bundles
The appliance can generate support bundles containing system configuration information and core files for use by remote support in debugging system failures. Support bundles are generated automatically in response to faults if the Phone Home service is enabled. Administrators can manually generate and upload a support bundle from this section of the Maintenance > System screen.
Once generated, support bundles are automatically uploaded to Oracle's Support files Service at http://support.oracle.com. To facilitate this, the appliance must be connected to the Internet, either directly or through the web proxy configured on the Phone Home service screen. If the upload fails, the system will make another attempt.
After a support bundle has been successfully uploaded, the support bundle and core files are automatically deleted from the system.
To generate a support bundle, click the image:Add item icon next to Support Bundles on the Maintenance > System screen. You are presented with the randomly generated filename for the support bundle. Provide this filename to support personnel so that they can retrieve your support bundle.
For each support bundle currently being generated or uploaded or which has failed to upload, the following options may be available:
Icon
Description
image:Cancel
Cancel the current operation. If the bundle is being generated, it will be deleted. If the bundle is being uploaded, the upload will be cancelled and the appliance will not retry it later.
image:Image
Download the support bundle.
image:Restart
Try again to upload the bundle to support.
image:Destroy
Cancel any pending operation and delete the support bundle.
To generate and upload a new support bundle, use the sendbundle command:
loader:> maintenance system
loader:maintenance system> sendbundle
A support bundle is being created and sent to Oracle. You will receive an alert
when the bundle has finished uploading. Please save the following filename, as
Oracle support personnel will need it in order to access the bundle:
   /cores/ak.9a4c3d7b-50c5-6eb9-c2a6-ec9808ae1cd8.tar.gz
As the message indicates, you must provide this filename to support personnel in order for them to retrieve your bundle.
Manage bundles from the maintenance system bundles context in the CLI, as follows:
loader:maintenance system> bundles
loader:maintenance system bundles> list
BUNDLE                                                  STATUS      PROGRESS
/cores/ak.9a4c3d7b-50c5-6eb9-c2a6-ec9808ae1cd8.tar.gz   Uploading      7%
Bundles are identified by the filename, omitting the ak. prefix and the file type suffix. To delete a support bundle, use the destroy command. To view details, use the select and list commands:
loader:maintenance system bundles> select 9a4c3d7b-50c5-6eb9-c2a6-ec9808ae1cd8
loader:maintenance system bundles 9a4c3d7b-50c5-6eb9-c2a6-ec9808ae1cd8> list
Properties:
          filename = /cores/ak.9a4c3d7b-50c5-6eb9-c2a6-ec9808ae1cd8.tar.gz
          status = uploading
                step_progress = 14.709744730821669
These read-only properties indicate that the appliance is 14% of the way through uploading the file. To retry a failed upload or cancel a pending operation, enter the retry and cancel commands respectively.
Initial Setup
Initial setup will step through the tasks performed as part of the initial configuration. This will not change any of the current settings unless explicitly requested. User data on the storage pool (including projects and shares) will not be affected.
To perform an initial setup:
Factory Reset
Factory reset will reset the appliance configuration back to factory settings of the current software version, and reboot the appliance. All configuration changes will be lost, and the appliance will need to go through initial configuration again, as when it was first installed. User data on the storage pool (including projects and shares) will not be affected - however the pool will need to be imported as part of the initial setup process.
To perform a factory reset:
Note: Factory reset of a single controller while configured into a cluster is not supported. The controller must be unclustered first.
