Skip Navigation Links
Exit Print View
Oracle Solaris Cluster Software Installation Guide     Oracle Solaris Cluster 4.1
search filter icon
search icon
Document Information
1.  Planning the Oracle Solaris Cluster Configuration
2.  Installing Software on Global-Cluster Nodes
3.  Establishing the Global Cluster
4.  Configuring Solaris Volume Manager Software
5.  Creating a Cluster File System
6.  Creating Zone Clusters
7.  Uninstalling Software From the Cluster
The Oracle Solaris Cluster Software Installation Guide contains guidelines and procedures for installing the Oracle Solaris Cluster 4.1 software on both SPARC based systems and x86 based systems.
Note - This Oracle Solaris Cluster release supports systems that use the SPARC and x86 families of processor architectures. In this document, “x86” refers to the larger family of x86 compatible products. Information in this document pertains to all platforms unless otherwise specified.
This document is intended for experienced system administrators with extensive knowledge of Oracle software and hardware. Do not use this document as a presales guide. You should have already determined your system requirements and purchased the appropriate equipment and software before reading this document.
The instructions in this book assume knowledge of the Oracle Solaris operating system and expertise with the volume manager software that is used with Oracle Solaris Cluster software.
Bash is the default shell for Oracle Solaris 11. Machine names shown with the Bash shell prompt are displayed for clarity.
Using UNIX Commands
This document contains information about commands that are specific to installing and configuring Oracle Solaris Cluster data services. The document does not contain comprehensive information about basic UNIX commands and procedures, such as shutting down the system, booting the system, and configuring devices. Information about basic UNIX commands and procedures is available from the following sources:
Typographic Conventions
The following table describes the typographic conventions that are used in this book.
Table P-1 Typographic Conventions
The names of commands, files, and directories, and onscreen computer output
Edit your .login file.
Use ls -a to list all files.
machine_name% you have mail.
What you type, contrasted with onscreen computer output
machine_name% su
Placeholder: replace with a real name or value
The command to remove a file is rm filename.
Book titles, new terms, and terms to be emphasized
Read Chapter 6 in the User's Guide.
A cache is a copy that is stored locally.
Do not save the file.
Note: Some emphasized items appear bold online.
Shell Prompts in Command Examples
The following table shows UNIX system prompts and superuser prompts for shells that are included in the Oracle Solaris OS. In command examples, the shell prompt indicates whether the command should be executed by a regular user or a user with privileges.
Table P-2 Shell Prompts
Bash shell, Korn shell, and Bourne shell
Bash shell, Korn shell, and Bourne shell for superuser
C shell
C shell for superuser
Related Documentation
Information about related Oracle Solaris Cluster topics is available in the documentation that is listed in the following table. All Oracle Solaris Cluster documentation is available at
Hardware installation and administration
Oracle Solaris Cluster 4.1 Hardware Administration Manual
Individual hardware administration guides
Software installation
Data service installation and administration
Data service development
System administration
Software upgrade
Error messages
Command and function references
Compatible software
Access to Oracle Support
Oracle customers have access to electronic support through My Oracle Support. For information, visit or visit if you are hearing impaired.
Getting Help
If you have problems installing or using Oracle Solaris Cluster, contact your service provider and provide the following information.
Use the following commands to gather information about your system for your service provider.
prtconf -v
Displays the size of the system memory and reports information about peripheral devices
psrinfo -v
Displays information about processors
pkg list
Reports which packages are installed
prtdiag -v
Displays system diagnostic information
/usr/cluster/bin/clnode show-rev -v
Displays Oracle Solaris Cluster release and package version information for each node
Also have available the contents of the /var/adm/messages file.
