Skip Headers
Oracle® Fusion Middleware Man Page Reference for Oracle Directory Server Enterprise Edition
11g Release 1 (11.1.1.7.0)
Part Number E28967-01
Go to Documentation Home
Home
Go to Table of Contents
Contents
Go to Index
Index
Go to Feedback page
Contact Us
Go to previous page
Previous
Go to next page
Next
PDF · Mobi · ePub
index-filter-analyzer-max-entries
DS suffix configuration (SUF) properties
Description
Each Directory Server suffix you create is configured according to the suffix properties documented here and in the documentation specified under the SEE ALSO section.
PROPERTY: compression-entries
Characteristic Value
Syntax
all|overflow
Default Value
overflow
Is readable
Yes
Is modifiable
Yes
Is multi-valued
No
This property specifies entry eligibility for compression.
all
All the entries will be compressed.
overflow
Only entries in overflow pages will be compressed.
PROPERTY: compression-mode
Syntax
none|DSZ
Default Value
None
Is readable
Yes
Is modifiable
Yes
Is multi-valued
No
This property specifies how entries are compressed.
none
No entries compression mechanism will be used.
DSZ
Entries will be compressed using the DSZ method.
PROPERTY: db-name
Syntax
STRING
Default Value
suffixName
Is readable
Yes
Is modifiable
No
Is multi-valued
Yes
This property specifies the suffix that is used to process requests involving the database.
PROPERTY: db-path
Syntax
PATH
Default Value
server-instance-dir/db/suffix-dir
Is readable
Yes
Is modifiable
Yes
Is multi-valued
No
This property specifies the absolute path to the suffix database.
PROPERTY: entry-cache-count
Syntax
INTEGER | unlimited
Default Value
unlimited
Is readable
Yes
Is modifiable
Yes
Is multi-valued
No
This property specifies the number of entries allowed in the entry cache of the suffix.
PROPERTY: entry-cache-size
Syntax
MEMORY_SIZE
Default Value
20M
Is readable
Yes
Is modifiable
Yes
Is multi-valued
No
This property specifies the maximum amount of memory Directory Server requests for the entry cache of the suffix.
PROPERTY: entry-count
Syntax
INTEGER
Default Value
0
Is readable
Yes
Is modifiable
No
Is multi-valued
No
This property specifies the number of entries stored in the suffix.
PROPERTY: entry-crc-enabled
Syntax
on | off
Default Value
off
Is readable
Yes
Is modifiable
Yes
Is multi-valued
No
Restart needed
No
This property specifies whether a CRC is computed on each entry.
PROPERTY: index-filter-analyzer-enabled
Syntax
on | off
Default Value
off
Is readable
Yes
Is modifiable
No
Is multi-valued
No
Restart needed
No
This property specifies whether the index filter analyzer is running.
PROPERTY: index-filter-analyzer-max-entries
Syntax
Integer
Default Value
2000
Is readable
Yes
Is modifiable
Yes
Is multi-valued
No
Restart needed
No
This property specifies the maximum number of entries that the index filter analyzer may contain.
PROPERTY: parent-suffix-dn
Syntax
DN | undefined
Default Value
DN of the parent entry
Is readable
Yes
Is modifiable
Yes
Is multi-valued
No
This property specifies the DN of the parent entry for the suffix. The value of this property must logically be a parent of the suffix.
For instance, if you have a suffix with DN dc=com and a suffix dc=example,dc=com, you can set dc=com as the parent-suffix-dn of dc=example,dc=com, and subtree searches with based DN dc=com then also travers dc=example,dc=com.
PROPERTY: referral-mode
Syntax
disabled | enabled | only-on-write
Default Value
disabled
Is readable
Yes
Is modifiable
Yes, if the suffix is not replicated
Is multi-valued
No
This property specifies how referrals are used when a client makes a request involving the suffix.
disabled
Handle requests locally; do not return referral URLs.
enabled
Return referral URLs to client requests.
only-on-write
Return referral URLs to client requests only for write operations.
PROPERTY: repl-accept-client-update-enabled
Syntax
on | off
Default Value
on
Is readable
Yes
Is modifiable
Yes
Is multi-valued
No
This property specifies whether the replicated suffix accepts write operations from client applications, or instead returns referral URLs.
PROPERTY: repl-cl-max-age
Syntax
DURATION | undefined
Default Value
7d
Is readable
Yes
Is modifiable
Yes
Is multi-valued
No
This property specifies the maximum age for a record in the replication changelog. Older records are purged.
PROPERTY: repl-cl-max-entry-count
Syntax
INTEGER
Default Value
0 (meaning undefined)
Is readable
Yes
Is modifiable
Yes
Is multi-valued
No
This property specifies the maximum number of records in the replication changelog. When the limit is exceeded, older records are purged.
PROPERTY: repl-id
Syntax
INTEGER
Default Value
None
Is readable
Yes
Is modifiable
Yes, using the subcommands to manage replication
Is multi-valued
No
This property specifies the replica identification number, 1-65534 for a supplier, 65535 for a consumer or a hub. Once set, this property cannot be modified.
PROPERTY: repl-manager-bind-dn
Syntax
DN | undefined
Default Value
undefined
Is readable
Yes
Is modifiable
Yes
Is multi-valued
Yes
This property specifies the bind DNs of users allowed to bind to perform replication operations on the suffix.
PROPERTY: repl-purge-delay
Syntax
DURATION | never
Default Value
7d
Is readable
Yes
Is modifiable
Yes
Is multi-valued
No
This property specifies the maximum age of tombstone entries used by replication. Tombstone entries are entries marked for deletion that have not yet been removed, and also replication state information associated with the entries. When setting this attribute, ensure that the purge delay is longer than the longest replication cycle in your replication policy to avoid incurring conflict resolution problems and divergence between replicas.
PROPERTY: repl-rewrite-referrals-enabled
Syntax
on | off
Default Value
off
Is readable
Yes
Is modifiable
Yes
Is multi-valued
No
This property specifies whether referrals you set can be automatically overwritten by the server to reference replicas.
PROPERTY: repl-role
Syntax
not-replicated | master | hub | consumer
Default Value
not-replicated
Is readable
Yes
Is modifiable
Is multi-valued
No
This property specifies the role played by the suffix in a replicated topology.
not-replicated
The suffix is not part of a replicated toplogy.
master
This suffix is a supplier of replication updates in a replicated topology. It can accept both read and write operations.
hub
This suffix is a supplier of replication updates in a replicated topology. It can accept read operations and replication updates.
consumer
This suffix is a dedicated consumer of replication updates in a replicated topology. It can accept read operations and replication updates, but not writes from clients.
To promote a replica, use the dsconf promote-repl command. To demote a replica, use the dsconf demote-repl command.
PROPERTY: require-index-enabled
Syntax
on | off
Default Value
off
Is readable
Yes
Is modifiable
Yes
Is multi-valued
No
This property determines whether unindexed searches are allowed. When on, unindexed searches return LDAP_UNWILLING_TO_PERFORM.
Syntax Values
Syntax values shown in lower case or partly in lower case are literal values.
Those shown in upper case are syntax types, defined as follows:
ATTR_NAME
A valid attribute type name such as cn or objectClass.
BOOLEAN
true or false.
DN
A valid distinguished name such as ou=People,dc=example,dc=com.
DURATION
A duration specified in months (M), weeks (w), days (d), hours (h), minutes (m), seconds (s), and miliseconds (ms), or some combination with multiple specifiers. For example, you can specify one week as 1w, 7d, 168h, 10080m, or 604800s. You can also specify one week as 1w0d0h0m0s.
DURATION properties typically do not each support all duration specifiers (Mwdhms). Examine the output of dsconf help-properties for the property to determine which duration specifiers are supported.
EMAIL_ADDRESS
A valid e-mail address.
HOST_NAME
An IP address or host name.
INTEGER
A positive integer value between 0 and the maximum supported integer value in the system address space. On 32-bit systems, 2147483647. On 64-bit systems, 9223372036854775807.
INTERVAL
An interval value of the form hhmm-hhmm 0123456, where the first element specifies the starting hour, the next element the finishing hour in 24-hour time format, from 0000-2359, and the second specifies days, starting with Sunday (0) to Saturday (6).
IP_RANGE
An IP address or range of address in one of the following formats:
  • IP address in dotted decimal form.
  • IP address and bits, in the form of network number/mask bits.
  • IP address and quad, in the form of a pair of dotted decimal quads.
  • All address. A catch-all for clients that are note placed into other, higher priority groups.
  • 0.0.0.0. This address is for groups to which initial membership is not considered. For example, for groups that clients switch to after their initial bind.
  • IP address of the local host.
LDAP_URL
A valid LDAP URL as specified by RFC 2255 (http://www.ietf.org/rfc/rfc2255.txt).
MEMORY_SIZE
A memory size specified in gigabytes (G), megabytes (M),kilobytes (k), or bytes (b). Unlike DURATION properties, MEMORY_SIZE properties cannot combine multiple specifiers. However, MEMORY_SIZE properties allow decimal values, for example, 1.5M.
NAME
A valid cn (common name).
OCTAL_MODE
A three-digit, octal file permissions specifier. The first digit specifies permissions for the server user ID, the second for the server group ID, the last for other users. Each digit consists of a bitmask defining read (4), write (2), execute (1), or no access (0) permissions, thus 640 specifies read-write access for the server user, read-only access for other users of the server group, and no access for other users.
PASSWORD_FILE
The full path to the file from which the bind password should be read.
PATH
A valid, absolute file system path.
STRING
A DirectoryString value, as specified by RFC 2252 (http://www.ietf.org/rfc/rfc2252.txt).
SUPPORTED_SSL_CIPHER
An SSL cipher supported by the server. See the Reference for a list of supported ciphers.
SUPPORTED_SSL_PROTOCOL
An SSL protocol supported by the server. See the Reference for a list of supported protocols.
TIME
A time of the form hhmm in 24-hour format, where hh stands for hours and mm stands for minutes.
Attributes
ATTRIBUTE TYPE ATTRIBUTE VALUE
Availability
SUNWdsee7
Stability Level
Evolving
See Also
dsconf(1M), all-ids-threshold(5DSCONF), db-path(5DSCONF), enabled(5DSCONF), moddn-enabled(5DSCONF), referral-url(5DSCONF)
