Perform these steps to obtain patches for the Oracle Solaris 10 OS.
When searching for a patch using the Patch Name or Number field, you must specify the complete name or number of the patch. For example:
To search using a patch number without the revision number (last two digits), type % in place of the revision number. For example:
147159-%
The patch README provides the patch installation instructions.
