Go to main content
SPARC T5-4 Server Service Manual
Exit Print View
Updated: February 2019
Rear I/O Module LEDs
The LEDs on the rear I/O module give server status information and link information on the NET ports.
image:Graphic showing the rear I/O module LEDs.
No.
LED
Icon
Description
1
AC1 connector LED
Indicates the state of the AC connector. Green indicates that the AC connector is functioning correctly. Amber indicates a fault with PSU1.
1
(Unused)
This LED has no function.
2
NET MGT link and activity LED (green)
Indicates the following conditions:
  • On or blinking – A link is established.
  • Off – No link is established.
3
NET MGT speed (green)
  • Blinking – A link is established.
4
NET link and activity (green)
  • On – A link is established.
  • Blinking – Transfer activity is present on the link.
5
NET speed (amber/green)
  • Green on – The link is operating as a 100-Mbps connection.
  • Off – There is no link.
6
(Unused)
6
AC0 connector LED
Indicates the state of the AC connector. Green indicates that the AC connector is functioning correctly. Amber indicates a fault with PSU 0.
7
System Locator LED and button(white)
image:Icon for the Locator Button/LED
The Locator LED can be turned on to identify a particular server. When on, it blinks rabidly. There are two methods for turning a Locator LED on:
  • Issuing the Oracle ILOM command set /System/Locator_indicator=on
  • Pressing the Locator button
8
System Service Required LED(amber)
image:Icon for the Service Required LED
Indicates that service is required. POST and Oracle ILOM are two diagnostic tools that can detect a fault or failure resulting in this indication.
The Oracle ILOM show faulty command provides details about any faults that cause this indicator to illuminate.
The System Service Required LED also illuminates on the rear I/O module if the rear I/O module has failed.
9
System Power OK LED(green)
image:Icon for the Power OK LED
  • Off – Server is not running in its normal state. Server power might be off. The SP might be running.
  • Steady on – Server is powered on and is running in its normal operating state. No service actions are required.
  • Fast blink – Server is running in standby mode and can be quickly returned to full function.
  • Slow blink – A normal but transitory activity is taking place. Slow blinking might indicate that server diagnostics are running or the server is booting.
10
Service Processor LED
SP
  • Off – The AC power might have been connected to the power supplies.
  • Steady on, green – The SP is running in its normal operating state. No service actions are required.
  • Blink, green – The SP is initializing the Oracle ILOM firmware.
  • Steady on, amber – A SP error has occurred and service is required.
11
System Overtemp LED(amber)
image:Icon for the Overtemp LED
Provides the following operational temperature indications:
  • Off – Indicates a steady state, no service action is required.
  • Steady on – Indicates that a temperature event has been detected and a service action is required.
Related Information
