Go to main content
SPARC T5-4 Server Service Manual
Exit Print View
Updated: February 2019
Remove a Hard Drive
Hard drives are hot-service components that can be replaced by customers. For the location of the hard drives, see Hard Drive Locations.
Caution
Caution  - This procedure requires that you handle components that are sensitive to electrostatic discharge. This discharge can cause failure of server components.
  1. Locate the drive in the server that you want to remove.
  2. Determine if you need to shut down the OS to replace the drive, and perform one of the following actions:
  3. Take the drive offline:
    1. At the Oracle Solaris prompt, type the cfgadm -al command to list all drives in the device tree, including drives that are not configured:
      # cfgadm -al
      This command lists dynamically reconfigurable hardware resources and shows their operational status. In this case, look for the status of the drive you plan to remove. This information is listed in the Occupant column.
      Example:
      Ap_id                       Type         Receptacle   Occupant        Condition
      c2                          scsi-sas     connected    configured      unknown
      c2::w5000cca00a76d1f5,0     disk-path    connected    configured      unknown
      c3                          scsi-sas     connected    configured      unknown
      c3::w5000cca00a772bd1,0     disk-path    connected    configured      unknown
      c4                          scsi-sas     connected    configured      unknown
      c4::w5000cca00a59b0a9,0     disk-path    connected    configured      unknown
      You must unconfigure any drive whose status is listed as configured, as described in Step 3.b.
    2. Unconfigure the drive using the cfgadm -c unconfigure command.
      Example:
      # cfgadm -c unconfigure c2::w5000cca00a76d1f5,0
      Replace c2::w5000cca00a76d1f5,0 with the drive name that applies to your situation.
    3. Verify that the blue Ready-to-Remove LED on the drive is lit.
  4. Press the drive release button to unlock the drive.
    image:Graphic showing how to remove a hard drive
  5. Pull on the latch to remove the drive from the server.
    Caution
    Caution  - The latch is not an ejector. Do not force the latch too far to the right. Doing so can damage the latch.
    image:Graphic showing steps for removing a hard drive
  6. Install the replacement drive or a filler tray.
    See Install a Hard Drive.
Related Information
