Go to main content
SPARC T5-4 Server Service Manual
Exit Print View
Updated: February 2019
Remove a Power Supply
The power supply is a hot-service component that can be replaced by a customer.
Caution
Caution  - This procedure requires that you handle components that are sensitive to electrostatic discharge. This discharge can cause failure of server components.
  1. Locate the power supply that you want to remove.
  2. Go to the rear of the server and locate the AC power connector at the rear of the server that supplies power to the faulty power supply.
    See Power Supply and AC Power Connectors.
  3. Disconnect that power cord.
  4. Go to the front of the server and, on the power supply to be removed, squeeze the release latches together, then pull the extraction lever toward you to disengage the power supply from the server.
    image:Graphic showing how to disengage a power supply.
  5. Pull the power supply out of the server.
    image:Graphic showing how to remove a power supply.
  6. Install the replacement power supply.
    See Install a Power Supply.
Related Information
