The fan module is a hot-service component that can be replaced by a customer.
Caution - This procedure requires that you handle components that are sensitive to electrostatic discharge. This discharge can cause failure of server components. |
See Fan Module Locations to determine if you can remove a fan module with the server running or if you must shut down the server before removing a fan module.
If you can remove a fan module with the server running, go to Step 3.
If you cannot remove a fan module with the server running, see Removing Power From the Server to power down the server before continuing.
