Go to main content
SPARC T5-4 Server Service Manual
Exit Print View
Updated: February 2019
Install a Fan Module
The fan module is a hot-service component that can be replaced by a customer.
Caution
Caution  - This procedure requires that you handle components that are sensitive to electrostatic discharge. This discharge can cause failure of server components.
  1. Insert the fan module into the empty fan module slot.
    The fan snaps into position with an audible click.
    image:Graphic showing how to install a fan module.
  2. Power on the server, if necessary.
    If you had to power off the server before removing and installing a new fan module, see Returning the Server to Operation to power on the server again.
  3. Verify the fan module functionality.
    See Verify a Fan Module.
Related Information
