Skip Navigation Links
Exit Print View
Sun Flash Accelerator F40 PCIe Card
User's Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Access to Oracle Support
Sun Flash Accelerator F40 PCIe Card Overview
Card Overview
About the Sun Flash Accelerator F40 PCIe Card
Key Features
Card Hardware Components
Card Software and Firmware Components
Card LEDs
Card Specifications
Physical Dimensions
Environmental Specifications
Electrical Specifications
Preparing the Card for Installation
Required Tools
Ship Kit Contents
Observing Safety Precautions
General Safety Information
Safety Symbols
ESD Safety Measures
Perform ESD Prevention Measures
Update the Host Operating System
Installing the Card
Installation Overview
Installing the Card Into a Server
Card Optimization Guidelines
Install a New Card
Remove an Existing Card From a Server
Servicing the Card
Service Overview
Update the Card Software
Update the Card Firmware
Technical Support
Servicing the Card Using the ddcli Utility
Accessing the ddcli Utility
Verify Card Status
ddcli Utility Command Summary
List All Command
List Command
Update Flash Package Command
Health Reporting Command
Locate Card Command
Format Card Command
Show the Vital Product Data Command
Extract SMART Logs Command
Help Command
Troubleshooting Using Card LEDs
Error Messages
Exception Handling
Firmware Exception Error Messages
Reason Codes
The Sun Flash Accelerator F40 PCIe Card operates and is stored in an environment defined by the following parameters:
Temperature range
  • Operatiing temperature: 0 °C to 74°C (measured at card temperature sensor)
  • Operational environment: 5 °C to 55°C (dry bulb)
  • Storage and transit environment: –20 °C to 75 °C (dry bulb)
  • Thermal sensor temperature cannot exceed 75 °C
  • Maximum dry bulb temperature shall be derated by 3.3 °C per 1000 m above 500 m
  • Four thermal sensors on the cards monitor each flash drive module
Relative humidity range
  • Operational environment: 8% to 80% noncondensing
  • Storage and transit environment: 5% to 95% noncondensing
  • Non-operating: -20°C to 75°C noncondensing
  • Operational environment: Up to 9840 ft (3,000 m)
  • Storage and transit environment: Up to 39,370 ft (12,000 m)
Airflow requirement
More than 200 LFPM (linear feet/minute)
The Sun Flash Accelerator F40 PCIe Card is designed to provide continuous full bandwidth performance with flash disk temperatures up to 73 °C. Qualified host platforms with required software updates operate with sufficient margin to the maximum temperature under worst case environments.
Should the system maximum operating temperature be exceeded, or a system fault occur which causes internal temperatures of the flash disks to rise above this limit, the card responds as follows:
Note - For specific site planning guidelines and best practices, refer to the server site planning guide and product notes for your server.
Related Information
