Sun Flash Accelerator F40 PCIe Card Overview
About the Sun Flash Accelerator F40 PCIe Card
Card Software and Firmware Components
Preparing the Card for Installation
Perform ESD Prevention Measures
Update the Host Operating System
Installing the Card Into a Server
Servicing the Card Using the ddcli Utility
Show the Vital Product Data Command
Troubleshooting Using Card LEDs
For specific PCIe card removal instructions, refer to the system service manual and product notes.
Refer to your server's service manual.
Power down the system.
Caution - Hazardous voltages are present. Disconnect the server from the main power and from any networks before installing the card to avoid electrical shock. |
Remove the bracket screw.
Carefully lift the card out of the PCIe slot to remove the card.
Caution - Hot surface. Avoid contact. Surfaces are hot and might cause personal injury if touched. Hazardous voltages are present. |
Figure 4 Sun Flash Accelerator F40 PCIe Card Removal
1 Bracket screw
2 Lift here
Refer to Install a New Card.
