Oracle ILOM
Properties That Affect POST Behavior
Note - The value of keyswitch_state must
be normal when individual POST parameters are
changed.
| Caution -
Setting the verbosity values to max will result in POST taking a longer
amount of time to complete its testing of the server.
Table 1 /HOST
keyswitch_state
normal
The server can power on and run POST (based on the other parameter settings). This parameter
overrides all other commands.
diag
The server runs POST based on predetermined settings.
standby
The server cannot power on.
locked
The server can power on and run POST, but no flash updates can be made.
Table 2 /HOST/diag
mode
off
POST does not run.
normal
POST runs according to diag
level value.
max
If diag
mode=normal, runs all the minimum tests plus extensive
processor and memory tests.
min
If diag
mode=normal, runs minimum set of tests.
Table 3 /HOST/diag
trigger
hw-change
(default) — Runs POST following a FRU replacement or an AC power cycle.
all-resets
Runs POST on all resets.
error-reset
Runs POST on all error resets.
power-on reset
Runs POST on every power on.
none
Does not run POST on reset.
Table 4 /HOST/diag
hw_change_level
max
Runs the maximum set of tests after a hardware change.
min
Runs the minimum set of tests after a hardware change.
Table 5 /HOST/diag
hw_change_verbosity
min
(default) — Displays the minimum level of output during the hardware change
tests.
max
Displays information for each step.
normal
Displays a moderate amount of information, including component names and test results.
debug
Displays extensive debugging information.
none
Disables the output.
Table 6 /HOST/diag
power_on_level
max
(default) — Runs the maximum set of tests.
min
Runs the minimum set of tests.
Table 7 /HOST/diag
power_on_verbosity
min
(default) — Displays the minimum level of output.
max
normal
debug
none
Table 8 /HOST/diag
error_reset_level
max
min
Runs a minimum set of tests.
Table 9 /HOST/diag
error_reset_verbosity
min
max
normal
debug
none
Table 10 /HOST/diag
verbosity
normal
Displays all test and informational messages in POST output.
min
Displays functional tests with a banner and pinwheel in POST output.
max
Displays all test, informational, and some debugging messages in POST output.
debug
none
Does not display POST output.
This flowchart illustrates the same set of Oracle ILOM set command
variables.
