Caution - This procedure requires that you handle components that are sensitive to static discharge. Static discharges can cause the components to fail. |
See Prevent ESD Damage.
Gently slide the front I/O assembly into position with the ports inserted into the port holes in the front of the main module.
Lower the rear of the front I/O assembly so that the captive screw is aligned with the screw hole on the motherboard.
