Go to main content
SPARC T5-8 Server Service Manual
Exit Print View
Updated: February 2019
Servicing Processor Modules
The SPARC T5-8 server supports two configurations:
  • Fully-populated — four processor modules
  • Half-populated — two processor modules and two processor filler modules
Processor modules and processor filler modules are cold-service components that can be replaced only by qualified service personnel. You must remove all power from the system before you attempt to remove the processor modules. For the location of the processor modules, see Front Panel Components (Service).
Caution
Caution  -  This procedure requires that you handle components that are sensitive to electrostatic discharge. This discharge can cause server components to fail.
These topics describe how to service the processor modules:
Related Information
