Go to main content
SPARC T5-8 Server Service Manual
Exit Print View
Updated: February 2019
Remove the Service Processor Card
The service processor card is a cold-service component that can be replaced only after you have removed the main module.
Caution
Caution  -  This procedure requires that you handle components that are sensitive to electrostatic discharge. This discharge can cause server components to fail.
  1. Determine your first step:
    1. If you cannot access the service processor card, go to Step 2.
    2. If you can access the service processor card, back up the SP configuration information.
      -> cd /SP/config
      -> dump -destination uri target
    where:
    • The acceptable values for uri are tftp, ftp, sftp, scp, http,and https.
    • target is the remote location where you want to store the configuration information.
    For example:
    -> dump -destination tftp://129.99.99.99/pathname
  2. Take the necessary ESD precautions.
    See Prevent ESD Damage.
  3. Remove the main module from the server.
    See Remove the Main Module.
  4. Locate the service processor card on the main module.
    See Main Module Internal Component Locations.
  5. Grasp the service processor card by the two grasp points, and lift up to disengage the service processor card from the connectors on the motherboard.
    image:Graphic showing how to disengage the service processor card from                             the motherboard.
  6. Lift the service processor card up and away from the motherboard.
    image:Graphic showing the service processor card being removed from the                             server.
Related Information
