Go to main content
SPARC T5-8 Server Service Manual
Exit Print View
Updated: February 2019
Determine if the Rear I/O Module Is Faulty
  1. Log in to Oracle ILOM.
    See Log In to Oracle ILOM (Service).
  2. Start the faultmgmt shell.
    -> start SP/faultmgmt/shell
    Are you sure you want to start the faultmgmt shell (y/n)? y
    faultmgmtsp>
  3. Use the fmadm faulty command to determine if the main module is operating normally.
    • If a fault was detected, see Diagnostics Process.
    • If no fault was detected, the main module is operating normally.
Related Information
