Go to main content
SPARC T5-8 Server Service Manual
Exit Print View
Updated: February 2019
Verify the Rear I/O Module
  1. Ensure that you have completed the following:
  2. Verify that the System Service Required LED on the rear I/O module is not lit.
    See Rear Panel Controls and LEDs.
  3. Log in to Oracle ILOM.
    See Log In to Oracle ILOM (Service).
  4. Start the faultmgmt shell.
    -> start SP/faultmgmt/shell
    Are you sure you want to start the faultmgmt shell (y/n)? y
    faultmgmtsp>
  5. Use the fmadm faulty command to determine if the server is operating normally.
    • If a fault was detected, see Diagnostics Process.
    • If no fault was detected, the rear I/O module was installed successfully.
Related Information
