Go to main content
SPARC T5-8 Server Service Manual
Exit Print View
Updated: February 2019
Remove a Card Carrier
The server supports single-wide and double-wide card carriers. The removal steps are the same for both carrier widths. This topic includes illustrations only for the single-wide carrier.
Note - If you are installing a PCIe card that requires a double-wide carrier, you must remove two single-wide carriers.
PCIe expansion cards with their carriers are hot-service components that can be replaced at any time if the card is not in use.
Caution
Caution  -  To remove a PCIe card that is assigned to an I/O domain, first remove the device from the I/O domain. Then, add the device to the root domain before you physically remove the device from the system. These steps enable you to avoid a configuration that is unsupported by the Direct I/O or SR-IOV feature. For more information about making hardware changes to an I/O domain, refer to the Oracle VM for SPARC documentation.
For the location of the PCIe card carriers, see Rear Panel Components (Service).
Caution
Caution  -  This procedure requires that you handle components that are sensitive to electrostatic discharge. This discharge can cause server components to fail.
  1. Take the necessary ESD precautions.
    See Prevent ESD Damage.
  2. Start this procedure with the primary domain at the Oracle Solaris prompt.
    Note - Removing a PCIe card carrier while the primary domain is at the Open Boot prompt is not supported.
  3. Locate the PCIe card carrier at the rear of the server.
  4. Determine if you are removing a card carrier from a running server.
    • If you are removing a PCIe card from a server that is running (that is, if you are hot-swapping the card), go to Step 5.
    • If you are removing a card from a powered-down server, go to Step 7.
  5. Take the card offline.
    You can use the Attention button or the CLI to hot-swap the card from the server.
    • Attention button:
      1. Press the button to bring the card offline.
        The Power OK LED should go off, indicating that the card is ready to be removed.
      2. Go to Step 7.
    • CLI:
      1. At the Oracle Solaris prompt, list all of the PCIe devices in the device tree:
        # hotplug list -l | grep PCIE
        This command lists dynamically reconfigurable PCIe resources and shows their operational status. In this case, look for the status of the card you plan to remove.
        Example:
        /pci@300/pci@1/pci@0/pci@6 [PCIE1] EMPTY
        /pci@340/pci@1/pci@0/pci@6 [PCIE3] ENABLED
        /pci@380/pci@1/pci@0/pci@a [PCIE9] EMPTY
        /pci@3c0/pci@1/pci@0/pci@e [PCIE11] EMPTY
        /pci@400/pci@1/pci@0/pci@c [PCIE2] EMPTY
        /pci@440/pci@1/pci@0/pci@c [PCIE4] EMPTY
        /pci@480/pci@1/pci@0/pci@4 [PCIE10] EMPTY
        /pci@4c0/pci@1/pci@0/pci@8 [PCIE12] EMPTY
        /pci@500/pci@1/pci@0/pci@e [PCIE5] EMPTY
        /pci@540/pci@1/pci@0/pci@e [PCIE7] ENABLED
        /pci@580/pci@1/pci@0/pci@a [PCIE13] EMPTY
        /pci@5c0/pci@1/pci@0/pci@8 [PCIE15] EMPTY
        /pci@600/pci@1/pci@0/pci@8 [PCIE6] EMPTY
        /pci@640/pci@1/pci@0/pci@8 [PCIE8] EMPTY
        /pci@680/pci@1/pci@0/pci@4 [PCIE14] EMPTY
        /pci@6c0/pci@1/pci@0/pci@4 [PCIE16] EMPTY
      2. Disable the PCIe card.
        Example:
        # hotplug disable /pci@340/pci@1/pci@0/pci@6 PCIE3
  6. Power off the PCIe card.
    Example:
    # hotplug poweroff /pci@340/pci@1/pci@0/pci@6 PCIE3
  7. Disconnect any transceivers, if applicable, and all of the cables connected to the PCIe card.
    Tip  - Label the cables to ensure proper connection to the replacement card.
  8. Pull the carrier's handle down to disengage the carrier from the card cage.
    image:Graphic showing how to remove a PCIe card from the server.
  9. Remove the carrier from the server.
    image:Graphic showing how to remove a PCIe carrier from the server.
Related Information
