Go to main content
oracle home
SPARC T5-8 Server Service Manual
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
SPARC T5-8 Documentation Library
Identifying Components
Fan Module Locations
Updated: February 2019
Document Information
Using This Documentation
Product Documentation Library
Feedback
Front Panel Components (Service)
Rear Panel Components (Service)
DIMM Locations
Main Module Internal Component Locations
Supported Storage Devices
Rear I/O Module Port Locations
Chassis Subassembly Components
Component Service Task Reference
Detecting and Managing Faults
Understanding Diagnostics
Diagnostics Process
Tool Availability
Log In to Oracle ILOM (Service)
Oracle ILOM Service-Related Tools
Interpreting LEDs
Front Panel Controls and LEDs
Rear Panel Controls and LEDs
Configuring POST
POST Overview
Oracle ILOM Properties That Affect POST Behavior
Configure POST
Run POST With Maximum Testing
Managing Faults
PSH Overview
Check for Faults
Clear a Fault
Interpreting Log Files and System Messages
Check the Message Buffer
View Log Files (Oracle Solaris)
View Log Files (Oracle ILOM)
Preparing for Service
Safety Information
Safety Symbols
ESD Measures
Antistatic Wrist Strap Use
Antistatic Mat
Tools Needed for Service
Filler Panels and Modules
Component Service Categories
Find the Server Serial Number
Locate the Server
Removing Power From the Server
Prepare to Power Off the Server
Power Off the Server (SP Command)
Power Off the Server (Power Button - Graceful)
Power Off the Server (Emergency Shutdown)
Disconnect the Power Cords
Prevent ESD Damage
Servicing Processor Modules
Server Upgrade Process
Processor Module LEDs
Determine Which Processor Module Is Faulty
Remove a Processor Module or Processor Filler Module
Install a Processor Module or Processor Filler Module
Verify the Processor Module
Servicing DIMMs
DIMM Configuration
DIMM Guidelines
DIMM Rank Classification
DIMM Locations
Determine Which DIMM Is Faulty (FMA)
Determine Which DIMM Is Faulty (LEDs)
DIMM Configuration Fault Messages
Remove a DIMM or DIMM Filler Panel
Install a DIMM
Verify the DIMM
Servicing Hard Drives
Hard Drive LEDs
Determine Which Hard Drive Is Faulty
Remove a Hard Drive
Install a Hard Drive
Verify the Hard Drive
Servicing the Main Module
Main Module LEDs
Determine if the Main Module Is Faulty
Remove the Main Module
Install the Main Module
Verify the Main Module
Servicing the Storage Backplanes
Remove a Storage Backplane
Install a Storage Backplane
Verify the Storage Backplane
Servicing the Service Processor Card
Determine if the Service Processor Card Is Faulty
Remove the Service Processor Card
Install the Service Processor Card
Verify the Service Processor Card
Servicing the System Configuration PROM
Remove the System Configuration PROM
Install the System Configuration PROM
Verify the System Configuration PROM
Servicing the Battery
Remove the Battery
Install the Battery
Verify the Battery
Servicing the Front I/O Assembly
Remove the Front I/O Assembly
Install the Front I/O Assembly
Verify the Front I/O Assembly
Servicing Power Supplies
Power Supply LEDs
Determine Which Power Supply Is Faulty
Remove a Power Supply
Install a Power Supply
Verify the Power Supply
Servicing Fan Modules
Fan Module LED
Determine Which Fan Module Is Faulty
Remove a Fan Module
Install a Fan Module
Verify the Fan Module
Servicing PCIe Cards
Understanding PCIe Root Complex Connections
Root Complex Connections (Four Processor Modules)
Root Complex Connections (Two Processor Modules)
PCIe Card Installation Guidelines
PCIe Carrier LEDs and Controls
Determine Which PCIe Card Is Faulty
Remove a Card Carrier
Remove a PCIe Card
Remove a Carrier Extension
Install a Carrier Extension
Install a PCIe Card
Install a Card Carrier
Verify the PCIe Card
Servicing the Rear I/O Module
Determine if the Rear I/O Module Is Faulty
Remove the Rear I/O Module
Install the Rear I/O Module
Verify the Rear I/O Module
Servicing the Rear Chassis Subassembly
Determine if the Rear Chassis Subassembly Is Faulty
Remove the Rear Chassis Subassembly
Install the Rear Chassis Subassembly
Verify the Rear Chassis Subassembly
Connect the Power Cords
Power On the Server (Oracle ILOM)
Power On the Server (Power Button)
Glossary
Index
Index Numbers and Symbols
Index A
Index B
Index C
Index D
Index E
Index F
Index H
Index I
Index K
Index L
Index M
Index N
Index O
Index P
Index R
Index S
Index T
Index U
Index V
Language:
English
No.
Description
Link
1
Fan module 5
2
Fan module 0
3
Fan module 6
4
Fan module 1
5
Fan module 7
6
Fan module 2
7
Fan module 8
8
Fan module 3
9
Fan module 9
10
Fan module 4
Previous
Next
