Go to main content
SPARC T5-8 Server Product Notes
Exit Print View
Updated: May 2016
Mandatory Oracle Solaris 11 OS Package Updates
No package update is required at this time to use the preinstalled Oracle Solaris 11.1 OS with this server.
If you reinstall the OS, you might need to install certain package updates before you put the server and optional hardware or software components into production.
Install the most recent Oracle Solaris 11.2 Support Repository Update (SRU). Taking this action ensures that your server has the latest software for the best performance, security, and stability.
Use the pkg info entire command to display which version is currently installed on your server.
Use the pkg command or the package manager GUI to download any available SRUs from: https://support.oracle.com
Note -  To access the Oracle Solaris 11 package update repository, you must have an Oracle support agreement that enables you to install a required SSL certificate and support key. Refer to the article at: http://www.oracle.com/technetwork/articles/servers-storage-admin/o11-018-howto-update-s11-1572261.html Go to Oracle's certificate request web site at: https://pkg-register.oracle.com.
