Go to main content
SPARC T5-8 Server Product Notes
Exit Print View
Updated: May 2016
Obtain Patches
Perform these steps to obtain patches for the Oracle Solaris 10 OS.
  1. Sign in to My Oracle Support:
    https://support.oracle.com
  2. Select the Patches & Updates tab.
  3. Search for a patch using the Patch Search panel.
    When searching for a patch using the Patch Name or Number field, you must specify the complete name or number of the patch. For example:
    • Solaris 10 1/13 SPARC Bundle
    • 13058415
    • 147159-03
    To search using a patch number without the revision number (last two digits), type % in place of the revision number. For example: 147159-%.
  4. After you locate the patch, access the README, and download the patch from the site.
    The patch README provides the patch installation instructions.
