Install a USB Drive
The server module has a USB port on the motherboard.
The USB port accepts USB drives that do not exceed a length of 45
mm.
- Prepare
for service.
See Preparing for Service.
- (If needed) Remove a USB drive.
See Remove the USB Drive.
- Locate the USB connector on the
motherboard.
See Component Locations.
- Plug your USB drive into the
upper port of the USB connector.
Do not use the lower port of this connector.
- Return the server module to operation.
See Returning the Server Module to Operation.
