Go to main content
SPARC T5-1B Server Module Service Manual
Exit Print View
Updated: February 2019
Verify the ID PROM
The host MAC address and the host ID values are stored in the ID PROM. This procedure describes ways to display these values.
  1. Display the MAC address that is stored in the ID PROM using one of these methods:
    • Using Oracle ILOM:
      -> show /HOST macaddress
      /HOST
      Properties:
      macaddress = 00:21:28:fa:26:96
    • Using Oracle Solaris and you are logged in with superuser privileges:
      # ifconfig -a | grep ether
       ether 0:21:28:fa:26:96
       ether 0:21:28:fa:26:97
    • When you are at the ok prompt:
      ok banner
      SUN BLADE 6000 MODULAR SYSTEM / SPARC T5-1B, No Keyboard
         Copyright (c) 1998, 2013, Oracle and/or its affiliates. All rights reserved.
         OpenBoot 4.35.0.build_28, 255.0000 GB memory available, Serial #102795976.
         Ethernet address 0:21:28:fa:26:96, Host ID: 85fa2696.
  2. Consider your next step.
Related Information
