Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Display information about targets, properties, and commands.
show [-d targets|properties|commands|all]|[-l 1|2|3...255|all][-o table][target][property property...]
where:
target is the target and path to act upon.
property is the property of the target to show.
This Oracle ILOM command displays information about targets, their properties, and associated commands. If no target is specified, information about the current target is displayed.
This table describes the options to the show command and their purposes:
This example shows how to display the Oracle ILOM user accounts with the show command.
-> show -d targets /SP/users /SP/users Targets: root ilom-admin ilom-operator for_Check test ->
