Skip Navigation Links
Exit Print View
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Access to Oracle Support
Installation
Understanding the Gateway
Gateway Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
NET MGT Connector and Pins
Data QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding Data Cabling
Preparing to Install the Gateway
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Optical Fiber Data Cables
Route the Data Cables
Installing the Gateway
Install the Gateway in the Rack
Powering On the Gateway
Connecting Data cables
Administration
Troubleshooting the Gateway
Gateway Hardware Problems
InfiniBand Fabric Problems
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Switch GUIDs Overview
Configuration Overview
Oracle ILOM Command Overview
Hardware Command Overview
InfiniBand Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Monitoring Gateway Resources
Controlling LAGs
Controlling VLANs and VNICs
Controlling Gateway Ports and Parameters
Remote Management
Understanding Oracle ILOM on the Gateway
Oracle ILOM Overview
Supported Features
CLI Overview
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Gateway Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Gateway Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (Oracle ILOM)
help Command (Oracle ILOM)
load Command
reset Command
set Command
show Command
version Command (Oracle ILOM)
Service
Detecting and Managing Faults
Interpreting Status LEDs
Managing Faulty Components
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Evaluating Sensor Alarms
Accessing CLI Prompts
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Determine If a Power Supply Is Faulty
Inspecting a Power Supply
Identify the Power Supply
Inspect the Power Supply Hardware
Inspect the Power Supply Connectors
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Determine If a Fan Is Faulty
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing Data Cables
Inspecting the Data Cables
Remove a Data Cable
Install a Data Cable
Servicing the Battery
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Replace the Battery
Reference
addlagport Command
allowhostconfig Command
autodisable Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
create_ipoib Command
createfabric Command
createlag Command
createvlan Command
createvnic Command
dcsport Command
delete_ipoib Command
deletelag Command
deletevlan Command
deletevnic Command
dellagport Command
disablecablelog Command
disablegwport Command
disablelagmode Command
disablelinklog Command
disablesm Command
disableswitchport Command
disablevnic Command
disallowhostconfig Command
enablecablelog Command
enablegwport Command
enablelagmode Command
enablelinklog Command
enablesm Command
enableswitchport Command
enablevnic Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
localmkeypersistence Command
matchtopology Command
modifyvnic Command
setcontrolledhandover Command
setdefaultgwdiscpkey Command
setgwethport Command
setgwinstance Command
setgwsl Command
setgwsystemname Command
sethostvniclimit Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsmrouting Command
setsubnetprefix Command
showdisk Command
showfree Command
showfruinfo Command
showgwconfig Command
showgwports Command
showioadapters Command
showlag Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
showvlan Command
showvnics Command
smconfigtest Command
smnodes Command
smpartition Command
smsubnetprotection Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
Index
  1. For residual power discharge, the power cord must remain unattached to the power supply for at least one minute before powering on a power supply.
  2. Identify the prerequisite and subsequent service tasks you must perform in conjunction with this procedure.
    See Servicing Power Supplies.
  3. Reconnect the power cord to the power supply.
    image:Illustration shows the power cord being installed.
    The AC LED lights green to indicate that the power supply is connected to facility power. A moment later, the OK LED lights green to indicate the power supply is at full power.
  4. Access the Oracle ILOM CLI.
    See Access the Oracle ILOM CLI (NET MGT Port).
  5. Enter the restricted Linux shell.
    See Enter the Restricted Linux Shell.
  6. Verify the power supply's operation with the checkpower and checkvoltages commands on the management controller.
    For example, to check the power supplies:
    FabMan@gateway_name->checkpower
    PSU 0 present status: OK
    PSU 1 present status: OK
    All PSUs OK
    FabMan@gateway_name->checkvoltages
    Voltage ECB OK
    Measured 3.3V Main = 3.30 V
    Measured 3.3V Standby = 3.42 V
    Measured 12V = 12.06 V
    Measured 5V = 5.03 V
    Measured VBAT = 3.17 V
    Measured 1.0V = 1.01 V
    Measured I4 1.2V = 1.22 V
    Measured 2.5V = 2.51 V
    Measured V1P2 DIG = 1.18 V
    Measured V1P2 ANG = 1.18 V
    Measured 1.2V BridgeX = 1.22 V
    Measured 1.8V = 1.80 V
    Measured 1.2V Standby = 1.20 V
    All voltages OK
Related Information
