Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
The preferred method of accessing the Linux shell is through the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
Using the show command on the /SYS/Switch_Diag target opens a restricted Linux shell that enables the ilom-admin user, ilom-operator user, and users with similar permissions to run diagnostic commands.
Using the show command on the /SYS/Gateway_Mgmt target opens a different restricted Linux shell that enables the ilom-admin user and users with similar permissions to run both diagnostic and gateway management commands.
Using the show command on the /SYS/Fabric_Mgmt target opens still an other restricted Linux shell that enables the ilom-admin user and users with similar permissions to run diagnostic, gateway, and fabric management commands.
Note - The ilom-operator user cannot access the Linux shell from either the /SYS/Gateway_Mgmt or /SYS/Fabric_Mgmt target.
This table lists the hardware commands and their availability from the respective Linux shell targets. Typing the help all command from within the restricted shells lists the commands available to that shell.
Note - Hardware commands that are not listed are unavailable from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, or /SYS/Fabric_Mgmt targets.
