Go to main content
Sun Network QDR InfiniBand Gateway Switch Product Notes for Firmware Version 2.1
Exit Print View
Updated: March 2017
Upgrade and Downgrade Paths Supported
The README files of previous firmware releases have omitted supported upgrade and downgrade paths.
This table identifies supported firmware version upgrade and downgrade paths.
From
To
1.1.x
1.3.x
2.0.x
2.1.2 - 2.1.6
2.1.7 - 2.1.9
1.1.x
Upgrade or Downgrade
1.3.x
  • Upgrade
  • Downgrade to 2.1.6 first
2.0.x
  • Upgrade
2.1.2 - 2.1.6
  • Upgrade
2.1.7 - 2.1.9
  • Upgrade
  • Upgrade
  • Upgrade
For example, upgrading from firmware version 1.1.2 to 1.3.5 is supported. However, upgrading from firmware version 1.1.2 to 2.1.5 is not. You must first upgrade from firmware version 1.1.2 to 1.3.x, and from firmware version 1.3.x to 2.1.5.
Similarly, downgrading from firmware version 2.1.6 to 2.0.7 is supported. However, downgrading from firmware version 2.1.9 to 2.0.7 is not. You must first downgrade from firmware version 2.1.9 to 2.1.6 using the downgrade version of firmware 2.1.6. Then you can downgrade from 2.1.6 to 2.0.7.
Note -  See Firmware Update Guidelines for information on upgrading and downgrading firmware.
