Replace a Gateway
This procedure briefly outlines the steps to replace a gateway within an
InfiniBand fabric. For more information, refer to the following books:
This procedure assumes that a secret M_Key policy is in use and the fabric is
partitioned.
Set the priority of the gateway to be removed to the lowest.
Wait for any handover to complete.
Create a backup of the gateway configuration for the gateway to be
removed.
Completely power off the gateway.
Remove the gateway from the fabric and management network.
Install and power on the replacement gateway, but do not connect it to the
fabric or the fabric's management network.
Configure the replacement gateway with the same hostname, IP address, and
lowest priority as the gateway removed.
Restore the gateway configuration previously backed up.
Completely power off the replacement gateway.
Connect the replacement gateway to the fabric's management network and the
fabric.
Power on the replacement gateway.
Wait for any negotiation and propagation to complete.
Perform a smpartition start and smpartition commit from the master Subnet
Manager.
Wait for the partition configuration to propagate to the replacement
gateway.
Perform a smsubnetprotection start and smsubnetprotection commit from the
master Subnet Manager.
Wait for the secret M_Key policy to propagate to the replacement
gateway.
Setup the smnodes file and fabric configuration file for the replacement
gateway, and ensure that the list and file are consistent with other gateway
and switch lists and files.
- (Optional)
Set the priority of the replacement gateway to the original priority of
the removed gateway.
