Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
InfiniBand Connector Parameters and Status
Switch Connector Parameters and Status
I4 Switch Chip Port Parameters and Status
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
In the rear panel diagram, there are 32 InfiniBand receptacles displayed, labeled 0A to 15A and 0B to 15B. Moving the mouse cursor over a connector name opens a small window that states the respective I4 switch chip port for that connector. This figure provides an example of moving the mouse cursor over the 0A for connection 0A.
When a connector is physically present in an InfiniBand receptacle, the receptacle changes from a black rectangle to a gray rectangle with three indicators.
This table describes the three indicators of the InfiniBand connection rectangle.
Moving the mouse cursor over an indicator that is orange or red opens a small window that states the reason for the respective state:
A left indicator is orange because the link has been autodisabled, either because of high error rate or suboptimal link speed and width.
A center indicator is orange because the link is at a speed slower than QDR, such as SDR or DDR.
A right indicator is red because there are errors (symbol, recovery, and so on) on the link.
This figure provides an example of moving the mouse cursor over the orange left indicator for connection 0A.
Clicking on the connection opens the InfiniBand connector status window for that connector. This figure provides an example of an InfiniBand connector status window.
At the top of the window are the connector name and the respective I4 switch chip port. There are four sets of information in the window, the cable FRU ID information, the link status, information about the I4 switch chip port (Switch Port), and similar information about the port's InfiniBand peer (Peer Port).
The cable FRU ID information includes:
Identifier
Connector type
Vendor
Vendor OUI
Part number
Revision
Serial number
Date of manufacture
The link information includes:
Link width, both enabled and active
Link speed, both enabled and active
High error rate present
Link state, status, and stability
The port information includes:
Device name and type
GUID, LID, and respective port
Link status and quality
Symbol errors
Recovery errors
Errors of various categories
Throughput statistics
Clicking Close dismisses the InfiniBand connector status window.
