Skip Navigation Links
Exit Print View
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Access to Oracle Support
Installation
Understanding the Switch
Switch Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
NET MGT Connector and Pins
InfiniBand QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding InfiniBand Cabling
Preparing to Install the Switch
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Optical Fiber InfiniBand Cables
Route the InfiniBand Cables
Installing the Switch
Install the Switch in the Rack
Powering On the Switch
Connecting InfiniBand cables
Administration
Troubleshooting the Switch
Switch Hardware Problems
InfiniBand Fabric Problems
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Switch GUIDs Overview
Configuration Overview
Oracle ILOM Command Overview
Hardware Command Overview
InfiniBand Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring Secure Fabric Management
Remote Management
Understanding Oracle ILOM on the Switch
Oracle ILOM Overview
Supported Features
Oracle ILOM Target Overview
Oracle ILOM Targets and Descriptions
Oracle ILOM General System Targets and Properties
Oracle ILOM Fan Targets and Properties
Oracle ILOM Indicator Targets and Properties
Oracle ILOM Power Supply Targets and Properties
Oracle ILOM Temperature Targets and Properties
Oracle ILOM Voltage Targets and Properties
Oracle ILOM Voltage State Targets and Properties
Oracle ILOM General Targets and Properties
Oracle ILOM Service Targets and Properties
Oracle ILOM User and Session Targets and Properties
CLI Overview
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Switch Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Switch Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (Oracle ILOM)
help Command (Oracle ILOM)
load Command
reset Command
set Command
show Command
version Command (Oracle ILOM)
Service
Detecting and Managing Faults
Interpreting Status LEDs
Managing Faulty Components
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Evaluating Sensor Alarms
Accessing CLI Prompts
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Determine If a Power Supply Is Faulty
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Determine If a Fan Is Faulty
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing InfiniBand Cables
Inspecting the InfiniBand Cables
Remove an InfiniBand Cable
Install an InfiniBand Cable
Servicing the Battery
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Replace the Battery
Reference
autodisable Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
create_ipoib Command
createfabric Command
dcsport Command
delete_ipoib Command
disablecablelog Command
disablelinklog Command
disablesm Command
disableswitchport Command
enablecablelog Command
enablelinklog Command
enablesm Command
enableswitchport Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
localmkeypersistence Command
matchtopology Command
setcontrolledhandover Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsmrouting Command
setsubnetprefix Command
showdisk Command
showfree Command
showfruinfo Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
smconfigtest Command
smnodes Command
smpartition Command
smsubnetprotection Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
Index
This table lists the Oracle ILOM /SYS/MB voltage parameter targets and their properties. Targets without properties are not listed.
Target and Path
Properties
/SYS/MB/V_1.8V
  • type = Voltage
  • ipmi_name = MB/V_1.8V
  • class = Threshold Sensor
  • value = 1.785 Volts
  • upper_nonrecov_threshold = 1.979 Volts
  • upper_critical_threshold = 1.940 Volts
  • upper_noncritical_threshold = 1.891 Volts
  • lower_noncritical_threshold = 1.697 Volts
  • lower_critical_threshold = 1.639 Volts
  • lower_nonrecov_threshold = 1.591 Volts
  • alarm_status = cleared
/SYS/MB/V_2.5V
  • type = Voltage
  • ipmi_name = MB/V_2.5V
  • value = 2.480 Volts
  • upper_nonrecov_threshold = 2.878 Volts
  • upper_critical_threshold = 2.679 Volts
  • upper_noncritical_threshold = 2.586 Volts
  • lower_noncritical_threshold = 2.387 Volts
  • lower_critical_threshold = 2.282 Volts
  • lower_nonrecov_threshold = 2.083 Volts
/SYS/MB/V_3.3VMain
  • type = Voltage
  • ipmi_name = MB/V_3.3VMain
  • value = 3.283 Volts
  • upper_nonrecov_threshold = 3.540 Volts
  • upper_critical_threshold = 3.454 Volts
  • upper_noncritical_threshold = 3.403 Volts
  • lower_noncritical_threshold = 3.112 Volts
  • lower_critical_threshold = 3.061 Volts
  • lower_nonrecov_threshold = 2.958 Volts
/SYS/MB/V_3.3VStby
  • type = Voltage
  • ipmi_name = MB/V_3.3VStby
  • value = 3.420 Volts
  • alarm_status = warning
/SYS/MB/V_5V
  • type = Voltage
  • ipmi_name = MB/V_5V
  • value = 5.018 Volts
  • upper_nonrecov_threshold = 5.902 Volts
  • upper_critical_threshold = 5.694 Volts
  • upper_noncritical_threshold = 5.486 Volts
  • lower_noncritical_threshold = 4.498 Volts
  • lower_critical_threshold = 4.290 Volts
  • lower_nonrecov_threshold = 4.108 Volts
/SYS/MB/V_12V
  • type = Voltage
  • ipmi_name = MB/V_12V
  • value = 11.966 Volts
  • upper_nonrecov_threshold = 12.710 Volts
  • upper_critical_threshold = 12.524 Volts
  • upper_noncritical_threshold = 12.338 Volts
  • lower_noncritical_threshold = 11.346 Volts
  • lower_critical_threshold = 11.160 Volts
  • lower_nonrecov_threshold = 10.974 Volts
/SYS/MB/V_BAT
  • type = Voltage
  • ipmi_name = MB/V_BAT
  • value = 3.120 Volts
  • upper_critical_threshold = 3.494 Volts
  • lower_noncritical_threshold = 2.746 Volts
  • lower_critical_threshold = 2.621 Volts
/SYS/MB/V_I41.2V
  • type = Voltage
  • ipmi_name = MB/V_I41.2V
  • value = 1.217 Volts
  • upper_nonrecov_threshold = 1.498 Volts
  • upper_critical_threshold = 1.462 Volts
  • upper_noncritical_threshold = 1.392 Volts
  • lower_noncritical_threshold = 1.041 Volts
  • lower_critical_threshold = 0.994 Volts
  • lower_nonrecov_threshold = 0.901 Volts
Related Information
